Where did you mount your Auto Meter shift light?
Old Jun 24, 2004 | 06:41 PM
lons94z's Avatar
Wondering if there is some place that works best?
Old Jun 27, 2004 | 11:21 PM
Bud M's Avatar
I put my shift light at the base of the A pillar
Old Jun 28, 2004 | 12:16 AM
ianwells100's Avatar
for a 97+, which i have, i got mine in one of the air vents, works perfectly, and is stealth
Old Jun 28, 2004 | 01:17 PM
94BlackBowtie's Avatar
I mounted mine right beside my automatic shifter.
Just kidding. I was going to suggest the air vents.
Old Jun 28, 2004 | 03:15 PM
Brandon 95 Z28's Avatar
Mine is to the right of the steering wheel, near the ac vent. Here are some pics:
http://www.u.arizona.edu/~mbb/car_pics.html
Brandon
Old Jul 1, 2004 | 10:06 PM
12SCNDZ's Avatar
Here.
http://www.geocities.com/max_wylde/interior.jpg
Frank
Old Jul 1, 2004 | 11:54 PM
look at the above posted pic
Old Jul 2, 2004 | 06:13 AM
lons94z's Avatar
OK a couple more questions
Red wire is pretty simple. Just go to the fuse block.
Where did you connect the green wire? I have heard that the pink/black wire going to the coil will give a tach signal.
And a simple wire....the ground. Where did you connect this? I would like to find SOME metal in or under the dash, clean it off, and attach the ground.
When I installed the scanmaster earlier this year I couldn't find any metal, and just ran it's ground to my fan switch's ground. (which runs right to the ground at the battery. Problem is I think this is the reason I keep getting a fan relay code. So I have to find some metal for both the shift light and the scanmaster.
Thanks for any help.
Old Jul 2, 2004 | 06:22 AM
12SCNDZ's Avatar
I got a wiring diagram for my car and tapped into the wire running to the factory tach, in the instrument cluster. I grounded it to one of the bolts coming through the firwall near the steering column.
Frank
jb4xx
Feb 2, 2015 10:00 PM
Jason Short
Jan 19, 2015 06:34 PM
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
