wheels
Old Sep 27, 2003 | 12:31 PM
95_LT1_6SPD's Avatar
wheels
Looking for new wheels for my z. Came across the american racing ones, the offset is for a corvette, is there any way to fix that?
http://www.americanracing.com/wheels...ted&section=C#
Old Sep 27, 2003 | 02:12 PM
chuckys95's Avatar
wait until you price those!!
Old Sep 27, 2003 | 09:41 PM
They show 54mm offset/7.357" backspace for the 17x9.5. That is fine for a 4th Gen F-body.
They show 58mm offset/7.75" BS for the 18x10.5, and that should fit the 4th Gen OK also. If it was really a 7.75" BS, the tire will sit about 1/4" further into the wheel well than a 17x11 GS offset ZR1. But there is something wrong with their numbers. A 58mm offset on a 10.5" wide wheel would usually produce an 8.0" BS, which puts the wheel too deep in the wheel well, and will be rubbing against the inner fender. To get a 7.75" BS on a 10.5" wide wheel, the offest would have to be 51mm. Something doesn't add up with the numbers that AR shows on the website. You might want to ask them to verify the numbers they show.
If in fact the wheel does turn out to have an 8.0" BS, you could use a 1/4" spacer to move it back toward the outside, but I'm not nuts about using spacers.
Old Sep 27, 2003 | 10:09 PM
Zack's Avatar
well, one of the salesmen at my job called up on those, and the rep from AR said they wont fit an fbody. Also, as Chucky mentioed, the prices on those wheels START at $795 A WHEEL and go up to $1000 A WHEEL
Old Sep 28, 2003 | 12:08 AM
Fastbird93's Avatar
Too bad, those are nice looking wheels too....
Old Sep 28, 2003 | 12:46 AM
Cmr0z28's Avatar
if I hit the lotto, I'll buy both of us a set.
Old Sep 28, 2003 | 10:10 AM
well, one of the salesmen at my job called up on those, and the rep from AR said they wont fit an fbody.......
If you call AFS, they will tell you you can't put their 17x11 wheels on a 4th Gen convertible.... they fit fine.... .
Something to think about.
Old Sep 28, 2003 | 11:22 PM
97TA-WS6-Con's Avatar
Yeah they seem to have there teeth in that urban myth for YEARS. I even sent them pictures of the wheels I bought from them and still they say they do not fit.
force10
Aug 10, 2015 08:30 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
jasonduaine
Jun 4, 2015 09:29 AM
