What paint to use to paint interior peices?
Old Aug 23, 2004 | 06:44 AM
Skyhawk's Avatar
Question What paint to use to paint interior peices?
I need to know what paint to use to paint my interior peices (their starting to fade so i decided to do something about it). Ive heard that Krylon Fusion is good but is there any better out there to use? Also, what kind of primer do yall use on it? And do you use clear coat? If so, what kind? I went to the store looking for some paint and there was so much to choose from. I want a shiney finish so do i sand, primer, paint, and then put clear coat on it?
Old Aug 23, 2004 | 07:47 AM
Bawls's Avatar
Re: What paint to use to paint interior peices?
I used duplicolor, same company primer. same company clear coat.id say sand primer paint sand clear.
Old Aug 23, 2004 | 10:20 AM
meissen's Avatar
Primer isn't needed, really. I've gone through and painted almost all the panels of my interior except the long skinny panel that runs along the driver and passenger side floor, and I haven't touched the passenger dash because I don't want to mess with that airbag module. Everything else I've painted over, and just used Krylon Fusion Gloss Black. Works great, doesn't run that easilly either. Just remember thin coats, and the great part about Fusion is that each coat is ready in 30 seconds, so you can do tons of layers in a short period of time. It's even ready for clear coat within an hour, compared to the day or so cure time for other paints. It dried pretty glossy for my tastes, but of course you can always clear coat afterwards. All in all, I definitely would recommend Fusion.
Old Aug 23, 2004 | 02:12 PM
BradleyPeart's Avatar
Fusion worked great for me!
Old Aug 24, 2004 | 04:06 PM
enzo1267's Avatar
does it look like it was stock or can you tell it was painted?
Old Aug 24, 2004 | 07:05 PM
meissen's Avatar
Here's some pictures of my painted interior. Depends on who you talk to, non-Camaro owners don't seem to notice..
This one is centered on the LEDs that I put in my headliner for courtesy lights, but you can still see the door and the back panel both were painted black and then the obvious red speaker covers and the reupholstered red vinyl panels.
And this one is a good example of difference between stock and the self-painted panels... the vent is stock black, never touched at all. Blends in perfectly with the Fusion-painted door panels.
Old Aug 30, 2004 | 10:23 AM
9428Green's Avatar
dang, your interior looks really good, nice job! I am painting my interior black and green, but i can't find any seat covers. Your doors look really sweet with the red vinyl! how did you do that? and how did you put those red LEDs in the headliner? looks good though! you should paint those front speaker grills red to match the rest of the door panels.
Nick
Old Aug 30, 2004 | 11:56 AM
PinoyPinay's Avatar
I used plasti-kote on mine and it seems to work well, I too also sanded the pieces, but did not bothered to prime...if u like to see results, it's on page 3 about halfway down of my cardomain site.
lates. good luck
Old Aug 31, 2004 | 11:37 AM
9428Green's Avatar
With the Plasti-kote you used, does it scrape off or peel when scraped or scratched?
Old Aug 31, 2004 | 05:24 PM
PinoyPinay's Avatar
With multiple coats and plenty of drying time in between, the paint is solid, I have hit the center gauge console with my keys and no scratch or dings...and there's no sign of peeling. My wife has fingernails and when she opens the door, there's no scratches on the paint...Just to remind you I used two different types of paint (enamel and lacquer - both are Plasti-Kote brands), if you look at page 8 of my cardomain site, i explain how i painted the interior...hope that helps.
Henson071
Dec 30, 2015 09:55 PM
TGGodfrey
Aug 18, 2015 06:08 PM
cmsmith
Aug 9, 2015 07:30 PM
Aug 5, 2015 08:35 AM
alphaauto
Jul 26, 2015 04:40 PM
