What is this inside the door?
Old Jan 18, 2021 | 10:31 PM
Displacement up's Avatar
Does anyone know what these little panels are called that are threaded and bolt to the hinge? Going to definitely need some new ones, but not sure where to look... or how to get these out.
Old Jan 18, 2021 | 11:33 PM
GaryDoug's Avatar
Prominent Member
Re: What is this inside the door?
I'm not sure what they are called but if I remember correctly they are just a small steel plate with three nuts attached. On my 98, they were removable from inside the door. Obviously your car is older, with steel doors, unlike the composite ones in my 98. What year?
Old Jan 19, 2021 | 09:10 AM
What year is the car?
When you posted 4 years ago you mentioned a 1974 Camaro.
Old Jan 19, 2021 | 11:19 AM
yep, it is the 1974. I think its called a hinge plate, but nobody seems to sell them. Or know of a good way to remove them. Everyone else I've asked has had problems with it rusting too but no solution.
Old Jan 19, 2021 | 11:47 AM
Can you pull the part out? If it's as simple as what Gary describes, should be easy to fabricate. Didn't see anything similar at the usual classic car parts outlets.
Old Jan 19, 2021 | 03:00 PM
it will require cuttingcand welding inside a place where I dont really think I can get that to fit. Would it be worth it to rip the door skin off, and reskin it? Might be what I need to do to get in there.
Bayer-Z28
9
Oct 2, 2006 10:18 PM
Pneumatic_Tire
3rd Gen / L98 Engine Tech
Jan 28, 2006 02:22 PM
$hawn
Jun 15, 2004 08:43 PM
Bila
Jun 3, 2004 12:45 PM
Savannah Dan
Jan 4, 2004 10:00 PM
