What do you think of my new black'd out interior?....90% done
Old Jul 8, 2007 | 10:20 PM
  #16
The Captain's Avatar
Trans Am Door panels FTMFW
Old Jul 8, 2007 | 11:59 PM
  #17
Donohue96M6Z28's Avatar
wow.. that looks bad ***.. good job.
Old Jul 9, 2007 | 04:36 PM
  #18
rexcellent's Avatar
looks great man! I went to Wal Mart last night and got some black dye to do my carpet. Did you pull all the carpet out and soak it in a big wash tub or something? How did you go about doing it?
Old Jul 9, 2007 | 04:50 PM
  #19
stroked 383's Avatar
Hopefully you got at least 3 bottles! I did 4 total and probably could've put more on.
The way I did it was I completely removed the carpet, laid it in the driveway and hosed it down completely. I had it completely wet, then put the dye into a spray bottle and just sprayed it down. I did about a 70% dye, 30% HOT water mixture to be able and spread the dye out. I did it 2x, let it dry and was going to put it back in but there was black dusting that got on everything it touched...so I washed it down and re-did it 2 more times. If you keep the carpet wet when doing it, the dye will distribute evenly.
After I was content w/ the color, and I couldn't wash out anymore residue from the carpet, I scotchguarded it up 3x total so it should be almost waterproof.
Just take your time, apply the dye evenly and you will be amazed at what you come up w/. Look at my old carpet before I stained it....I thought it was long gone and this was just an attempt...but now it looks as good if not better than a new carpet and it cost me very little but some time.
Any other q's don't hesitate... I had to figure this all out myself and had quite a bit of trial and error... it kept things interesting!
This was after 2 coats...just needed to be darker for me.
Old Jul 9, 2007 | 05:00 PM
  #20
BTW, I used the liquid dye...not the powder!
Old Jul 9, 2007 | 05:03 PM
  #21
mdacton's Avatar
Did you do a new headliner or dye the old one?
I might do some of this on my firebird
Old Jul 9, 2007 | 05:12 PM
  #22
rexcellent's Avatar
thanks for the advice. All I could find was powder dye so hopefully that will work. Ill just put it in something that I can spray with and do it the same way. I might try to even find a tub or something big enough to soak it in. Ill probably do it this weekend, Ill let you know how it turns out.
Old Jul 9, 2007 | 06:51 PM
  #23
I re-did it. Strip off all the old fabric, use a green brillo pad and get the foam off. Then go to a fabrics store, I used JoAnn's fabrics, and get some headliner fabric. Apply w/ some spray adhesive and thats it. If you have t-tops, its a pain in the *** to stretch around that inner curve.
Powder dye should be fine. If you could fit it in a tub, it'd def be even....I didn't want to dye my tub. Let me know how it works out for future reference if you would though!
Old Jul 9, 2007 | 06:54 PM
  #24
bderlan's Avatar
for the plastic panels did you prime and clear coat them. because i painted mine black(no prime or clear) and the piece beside the drivers seat is losing paint from getting in and out.
Old Jul 10, 2007 | 09:43 AM
  #25
d2stephen's Avatar
Looks good.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
F'n1996Z28SS
Jun 3, 2015 09:39 AM
1970judge
Cars Wanted
May 23, 2015 11:39 PM
