What billet grills are out there for a 95 Z28?
Just wondering. I'm kinda getting tired of the stock front. I'm going to take out the fog lights (one burnt out, and I never bothered replacing it).
Then I'm going to take off the front plate and plate bracket and put on the billet grill. Then put on the plate back on with a custom bracket because we need front plates here in MO.
I looked at the RKSport grill, and its spaces between the grills were too large, I was looking for something tight so you cant really see through it. Anyone have links to other manufacturer's grills?
Thanks!
Thanks!
Re: What billet grills are out there for a 95 Z28?
Can you please explain me more about this bracket because i have this grill on the way to me and we have a very strict law about the front plates in here. I was thinkig to modyfy my stock bracket to go over the grill but it will probably look like $hit.
Alex
You can always mount your plate below, if you don't want to cover up the grill...
http://images.cardomain.com/installs...8_349_full.jpg
Originally posted by catsnet
Hey Kain
Alex
Hey Kain
Alex
My original plan: I was g4oing to mount a metal plate behind the grill, roughly the size of the license plate. Then drill holes in the metal plate where the holes of the license plate are, then have bolts and locking nuts to attach the two through the slits in the grill.
Looking at it, I see the grill is to narrow to directly shove the bolts through, I'd have to make some U brackets (out of plumbers tape, its solid metal "tape", with holes in it. Its for securing and holding up hot water heaters. You can get it at Home Depot) to connect the two because the two sets of holes would be offset. That'd be my best guess. I can always rig up something.
Make one...
I have always thought it would look pretty good to make one out of this aluminum gutter screen stuff...sounds kind of ratty, but I don't think it would look too bad...that stuff is pretty inexpensive, and could be done pretty easy I think...
Just a thought...
Just a thought...
Dec 17, 2014 11:00 AM
2000silverz28
Sep 7, 2002 01:48 AM
2000silverz28
Jul 20, 2002 06:14 AM
