Waxy-like "Zeibart" material sprayed in engine bay > Need to remove
Old May 29, 2003 | 12:50 PM
Kimchee & Rice's Avatar
I wonder if our 95 TA was coated with some kind of rustproofing material like Zeibart or something. There is a semi-clear waxy substance sprayed on all the painted surfaces under the hood. The car is black, but these painted surfaces are a very dull black. I have pealed a little of it off revieling a shiny black paint below it.
How do you get this crap off? I have tried Brake Cleaner, Carb Cleaner..... Nothing seems remove it. I would try Laquer Thinner, but that will more than likely remove not only this waxy crap, but the paint under it too.
Ron,
98 TA / Heads, Cam, Headers car
95 TA / Procharger
Old May 29, 2003 | 07:01 PM
AW/whiteZ-28's Avatar
Did you use a hard bristle brush too or a rag?
If not use a brush too
Old May 29, 2003 | 07:21 PM
Marky82's Avatar
Try rubbing compound
Old May 30, 2003 | 09:27 AM
Brent94Z's Avatar
Super Moderator
This is probably nothing more than one of the cheap used car dealer detailing tricks.
Rather than spend the money on good vinyl/rubber dressing, sometimes they buy the $0.88 cans of clear coat paint. They then coat EVERYTHING under the hood of the car. Looks GREAT for about 3 months (the time it takes to sell the car) then starts to turn cloudy and peel.
I'd bet you a beer that is nothing more than clear coat paint out of a paint can in your engine compartment.
DirtyDaveW
Dec 1, 2016 05:37 PM
David Dorris
Jan 17, 2015 08:10 PM
formula218
Dec 2, 2014 04:27 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
