Water leaks
Old Nov 12, 2002 | 12:14 PM
quick's Avatar
Water leaks
I have a 1998 SS with T-Tops, and it's been exposed to the torrential downpours that have occurred in my area recently. The lower part of the trunk area, the deep part where the t-tops are stored, is filling with water. Can any of you suggest any trouble-shooting techniques to find the source of the leak and fix it?
Thanks a lot.
Old Nov 12, 2002 | 09:21 PM
ibanez6rg's Avatar
Maybe it's leaking from underneath and getting in somehow. I can't think of any other ways it could get in.
Anymore details?
Old Nov 13, 2002 | 09:54 AM
anasazi's Avatar
how deep? there is a drain hole benieth the spare tire taht should drain the water out... but you shouldn't have water back there in the first place
get someone to lean over the back seat and look for leaks while you pour water on the rear using a hose.
Old Nov 13, 2002 | 01:44 PM
quick's Avatar
More details
The drain plugs are in place--I did remove one to get most of the water out. The main gasket on the lower part of the opening looks fine. My guess is it's coming in around the lower edge of the hatch glass, just before you get into the spoiler. The grey plastic trim that sits on the inside of the hatch seems suspicious. Can that be easily removed so I can inspect the glass its installation from inside of the hatch?
Thanks.
Old Nov 18, 2002 | 11:47 AM
fbird95's Avatar
Check the rear hatch seal. It tends to leak over time. Just reseal it with adhessive.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
madwolf
Aug 2, 2001 08:32 AM
