Vizage Body Kit
Old Nov 4, 2003 | 04:07 PM
Maro98's Avatar
Question Vizage Body Kit
I just got my new Vizage kit today, and I installed the right side there is a small area where there is about a 1/4 inch gap between the kit and the body that I cant do anything to get to meet up. Is there anything I can put in the gap, like body filler or something? If so what do I need? Thanks in advance.
Old Nov 4, 2003 | 08:53 PM
tend2609's Avatar
well, i would say go talk to a body shop, i work at one, but i am not sure of what to do to make sure it is stong, the best i can say right now is some fiberglass
Old Nov 5, 2003 | 07:57 AM
v7guy's Avatar
it depends, if it's urethane and it's just twisted you could use a heat gun to pull it into shape, it's a common practice
Old Nov 5, 2003 | 10:09 AM
catsnet's Avatar
Re: Vizage Body Kit
I had the same problem with the kit
had to grind a bit on the sides and still have to reinstall the back coz it just doesn't fit right. what I did on the side is I grinded the inner corners so they came up less rounded and they are still not perfect but way better now. the rear is still sticking out for ablut 1/4" but I guess it will have to be done by pros when I'll be re painting the car in a year.
the bottom line is the fitment on this kit is very very poor to start with but you have to work in order to look good
Old Nov 5, 2003 | 11:27 AM
Maro98's Avatar
Well the problem is, the bottom of my quater panel sticks out a little further than the piece under my door. I guess ill just take it to a body shop and see what they say.
CARiD
Feb 9, 2015 09:35 AM
CARiD
Jan 14, 2015 04:00 AM
rockync7
Jan 1, 2015 05:10 AM
CARiD
Dec 26, 2014 04:20 AM
RedLineRev
Jan 23, 2003 03:51 PM
