Vinyl CAMARO Steering Wheel Letters
Old Jan 26, 2003 | 12:06 PM
  #91
Brent94Z's Avatar
Super Moderator
Thanks again guys. Glad you like them I've already bought some camaroz28.com merchandise and plan on buying another item or two with this money to put back into the site.
I also don't recommend using "soapy water". When I use soapy water to install vinyl I use ONE DROP of soap per bottle of water. If you use too much soap you'll have trouble getting them to stick as I suspect your problem is anasazi. Water evaporates... soap doesn't evaporate too well. If your concentration is too strong the soap will remain under there and won't allow the adhesive to stick. If it doesn't start sticking after a few days of "drying" (because of too much soap ) then pull those out and use the extras I sent along for you! You also don't need to use the water... I didn't when I stuck mine in. You just need to be a little more careful and since there is an extra set you can afford to mess up once
I've been sending an extra set in case this kind of stuff happens because these are so small.
Greasepunk, you can check out my web page for info on some of the other stuff.
Old Jan 26, 2003 | 12:41 PM
  #92
anasazi's Avatar
i didn't use soap and water. i tried doing it without at first and i found i could do it really well without the use of soap and water, but its still not sticking very well
is there some sort of glue i can use?
oh, i just snapped these pics... it looks sweet
http://anasazi.sytes.net/wheelinsert/
Old Jan 26, 2003 | 03:18 PM
  #93
stik6shift98's Avatar
how much are u asking for the steering wheels letters in red
thanks
they look sweet as hell
Old Feb 22, 2003 | 12:57 AM
  #94
Indy93Z28's Avatar
Wow that looks really nice! I want some in white... do you accept anything besides CCs for payment?
Old Feb 22, 2003 | 11:27 AM
  #95
Brent94Z's Avatar
Super Moderator
You can send a money order if you'd like. I have my address and other stuff on this page...
http://www.bfranker.badz28.com/vinyl/vinyl.htm
Also, for anybody who was interested, I have been working on the AIR BAG inserts. They don't look as good because the dash is still "dimpled" under the letters and the indented area isn't nearly as defined. I made some but don't like them. I'm going to try and make the letters a bit "thinner" to see if that will help with the appearance. If I can get something I'm happy with, I'll let you guys know. Thanks!
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
turbo_Z
Aug 19, 2002 10:50 PM
