Trans Am -> Formula
Old Jan 11, 2004 | 04:42 AM
aram's Avatar
Trans Am -> Formula
I found someone locally who wants to trade me my LT1 T/A front bumper, rear bumper, sideskirts and hatch for his v6 bumpers and hatch. I wanted to save some weight and ever since I bought a formula that someone crashed into I always like the formula look better.
Anyone know if the side skirts will just come off without leaving any holes or anything like that? I know the rest of the stuff should just swap right over.
Old Jan 11, 2004 | 11:10 AM
caspergotaz28's Avatar
Lightbulb
I am 99% sure there would be some holes left. I seriously doubt those side skirts are mounted with double-sided tape alone.
Lay up under you rocker and take a look at the hardware.
Old Jan 11, 2004 | 12:21 PM
Skull Leader's Avatar
You'll save probably 10 ounces. Have you picked up the side skirts? The front bumpers aren't that different either. I picked up a TA and a Formula bumper at a junkyard once and I couldn't tell the difference.
Old Jan 11, 2004 | 01:09 PM
aram's Avatar
The rear spoiler is the big difference.. the stock one supposedly weighs about 35 #'s and the side skirt weight is probably only 5-10 #'s.. that's still 40-45 #'s and I like the look better. When you are trying to pull weight off your car 40#'s is huge. A aftermarket k-member does not save close to that much weight and I need to get the front an rear bumper's painted anyway.
Anyone actually know if there are holes under the sideskirts instead of guessing?
Old Jan 11, 2004 | 01:54 PM
Zack's Avatar
the side skirts are held on under the car, and inside the wheel wells
Old Jan 11, 2004 | 09:14 PM
aram's Avatar
Thanks.. So when they are removed you can't see any marks from them I assume? I would go take one off to see but my car is kind of far away (500 miles) right now.
I was actually thinking of seeing if I could just find the hatch and front and rear bumpers at a local junkyard for cheap and keep my stock TA parts, so then if I wanted to switch back later I could. It seems like the v6 firebird parts are not nearly as hard to find and are much cheaper than the TA stuff.
I also would really like to weigh the difference between the parts to see how much it really is.
Old Jan 11, 2004 | 10:03 PM
neil350's Avatar
The side skirts are maybe 4lbs for the both of them. A shop broke mine and they paid for a new one.
Jlo
Jun 24, 2015 11:55 AM
Chophouse
Jun 18, 2015 08:25 AM
Jan 13, 2015 09:52 PM
Jazsun
Dec 29, 2014 12:14 PM
jrp4uc
Sep 8, 2002 04:44 AM
