Trans Am Dash Swap
Old Jan 2, 2005 | 06:11 PM
Z95m6's Avatar
Trans Am Dash Swap
This was one of the most PITA installs i've ever done on an Fbody. I'm glad its over with. The Donor car was a friends 93 TA that i now have the complete interior out of. I have new TA seat covers on the way now too. The only interior part in my car thats not from his is the 97+ console and my Bose which will be replaced with a TA one tom. The install and wiring was exactly the same as a 97+ dash swap. I used the same wiring diagram as the 97+ Camaro dash swap. Here are the pics.
http://www.mustangmods.com/data/1787/camaro_dash.jpg
http://www.mustangmods.com/data/1787/trans_am_dash.jpg
Let me know what you guys think.
Old Jan 2, 2005 | 06:15 PM
jbsupra89t's Avatar
Re: Trans Am Dash Swap
Looks good. I remember pulling the dash of a front clip I had. No windshield and even then it was one of the biggest PITAs I've ever been associated with. Installing one in an actual car? Nice job.
-J
Old Jan 7, 2005 | 11:33 AM
XxXTransAmXxX's Avatar
Yay I start pulling mine today!!! Within the hour, and pointers?
Old Jan 7, 2005 | 12:10 PM
Z95m6's Avatar
just be patient. Also make sure you remove the bracket that bolts to the floor behind the console first. i removed everything else and then noticed that bolt down there. I then had to try to hold up the dash while taking out the bolt. It was a bitch. I had the TA dash out in 1.5 hrs. Taking my time as it was my first dash removal and i didn't want to mess anything up. Removing the Camaro Dash was a bitch. Why are you removing yours?
Old Jan 7, 2005 | 12:12 PM
I need the HVAC unit outta the EngineBay, I'm grinding the paint off for fresh basecoat/clearcoat blk paint while the motor's out...The HVAC and Brake Booster Assy are preventing me from getting into the back 2 corners for paint removal and prep, but you have to pull th dash to get to them. Also I figure I'll put a 97+TransAm Dash Harness in so I can runt he digital odometer cluster...
Old Jan 7, 2005 | 01:07 PM
Skull Leader's Avatar
Exclamation Re: Trans Am Dash Swap
I can't believe you did that!!!!!! I would have traded you in a heartbeat. I hate those big *** AC vents.
Old Jan 7, 2005 | 11:16 PM
Z95m6's Avatar
I have the Camaro dash left over. I would be willing to trade you everything you need for the Camaro dash for some of your dash parts. I wouldn't mind having a 97 gauge cluster, and i need the top dash pad.
Old Jan 8, 2005 | 01:13 AM
6SpdLT1Z's Avatar
Looks clean, though I couldn't change my dash, I'm so used to it.
Old Jan 8, 2005 | 05:05 PM
Craddock's Avatar
It looks like it belongs there, but I couldn't do it to my dash either. I like the way it is set up, especially with the way it is driver oriented. I have an 8 year old little brother who likes to touch anything of mine that is expensive, especially electronic stuff like my radio.
Old Jan 8, 2005 | 06:16 PM
Z95m6's Avatar
The trans am dash is pretty much the 97+ Camaro Dash. They are even wired the same. I wanted to install a 97+ Camaro Dash but this TA dash was free.
Old Jan 8, 2005 | 09:36 PM
Craddock's Avatar
I like the way mine is now, where the controls and radio face the driver. I'm driving my 92 Jeep right now, and it sucks having to reach off to the side in it. I have to look off the road to change the radio or heat. If I sit closer, than it cramps my legs. I can sit back at just the right spot in my car, and still comfortably reach the radio and heat.
Brake_L8
Jan 20, 2015 09:44 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
