tire sizes
Old Apr 12, 2003 | 04:00 PM
jgonzales's Avatar
tire sizes
I'm looking for some wheels, but I haven't decided what size yet. The price of tires is a determining factor, but I don't know what size tires fit on what size wheels (width). And I'd also like to know the overall height of the tire. Does anyone know of a website with some kind of chart or something that has all this information? Thanks...
Old Apr 12, 2003 | 06:30 PM
naaz90's Avatar
Im guessing you have 16 inch rims now, right? If you do then you most likely have 245/50-16, which is on a 16x8in rim. You should jump up to 17x9.5in rim.
The tire size you should go with that will not run into any fitmet problems would be 275-40-17.
www.tirerack.com recomends a tire size depending on what rim you choose.
Old Apr 14, 2003 | 04:21 PM
jgonzales's Avatar
I wanted to get at least 10" wide on the back, and I wanted to get a little taller tire to offset the low gears for better gas mileage. That's why I needed to know tire height for the different sizes. Anyone have any idea where I can find this info?
Old Apr 14, 2003 | 04:46 PM
93Z286Speed's Avatar
the taller and wider the rim the more the tires are.. simple as that..
and if traction is a BIG issue id go with some wide 16s or even 15s
a 45-35 series tire dosent have enough sidewall flex, or not as much as a 50-65 will..
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
LD Kirk
Apr 30, 2015 08:54 AM
blac94Z
Mar 6, 2015 07:55 AM
cristian1311
Mar 4, 2015 04:45 PM
