Tip on how to re-install factory grille
Old Oct 25, 2003 | 07:39 AM
CODY BEHNKE's Avatar
Well I simply replaced my grille since mine had a plate frame mounted to it. I used the pull it off method to remove it. And here is how I re-installed it. I thought about removing the front fascia but I didn't have time.
1- Cut off 3, 1.5 inch segments of emissions tubing
2- Put one piece on each upper mounting post on the grille
3- Re-mount grille pushing top in first
4- Reuse the bottom clips
I tested mine to see if it would stay in and it was on tighter this way than with the factory clips.
HibachiZ28
Nov 6, 2015 12:53 AM
Aug 7, 2015 08:52 AM
Aug 5, 2015 08:35 AM
Jul 17, 2015 02:47 PM
pimpen1024
Jul 8, 2015 09:08 PM
