Is there any way to...
Old Oct 20, 2003 | 01:00 PM
Garage Inc.'s Avatar
Question Is there any way to...
Take the white stripe off of the sides of a car?
It's on a '98 Firebird, black paint with white lines going across each side (very thin)...can they be rubbed out somehow or only professionally?
Old Oct 20, 2003 | 02:32 PM
Fallchild000's Avatar
I dont know exactly what you're talking about, but if they are pin stripes, most likely they are stick on. With a lot of patients, you should just be able to peel it off. If you had a heat gun that would work too.
Good Luck
Nathan
Old Oct 20, 2003 | 02:34 PM
chevroletfreak's Avatar
Sounds like a pinstripe.....just pick at a corner of it and then peel the rest off slowly. You can just wash off the residue or there are adhesive removers on the market to clean up the left over sticky stuff.
Old Oct 20, 2003 | 06:55 PM
AllShowNoGo's Avatar
Just dont use degreaser on BLACK, when I peeled off pinstriping on a 02 Mustang GT it burned the paint and made it look primer
Old Oct 20, 2003 | 07:03 PM
FLyinlow89's Avatar
WD-40 is good for glue removal
Old Oct 20, 2003 | 07:54 PM
Thanks a lot everyone...yeah, pinstripe is what it is...it's very thing and starts from the rear, straight to the front and curves down at the end a little
if I knew I could take it off, I'd buy the car I'm looking at..thanks again
EDIT: heres a pic
http://www.showauto.com/viewfull.asp?ID=799203
Old Oct 20, 2003 | 08:19 PM
ImportKILLER's Avatar
I have those on my white camaro...the pinstripe is like a burgandy color.
I'm tempted to...yet am almost afraid to. Doesn't make sense but...bleh.
Noct
May 26, 2016 10:26 AM
lankie_25
Jun 30, 2005 07:52 PM
