tb plate question?
Old Dec 6, 2002 | 04:10 PM
PaulN64's Avatar
Question tb plate question?
does the tb plate actually does anything or is it just there to take up space?
Old Dec 6, 2002 | 04:48 PM
onoiocoko's Avatar
pretty sure its there for looks. like u can get Z28 on ur plate or something to dress up ur engine. hope this helps.
Old Dec 6, 2002 | 04:52 PM
PaulN64's Avatar
I was jut wondering if it actually did anything or just dead weight...if it's just dead weight, I'm just going to take it off when I do the TB bypass
Old Dec 6, 2002 | 05:14 PM
onoiocoko's Avatar
im not really sure if where talking about the same thing. im talking about the after market ones people usually get on the top of their TB? did someone put it on ur car befor u got it or does it look like a factory part? i think its just dead weight if its the one im talking about.
Old Dec 6, 2002 | 05:21 PM
PaulN64's Avatar
I'm referring to the plate which sits on top of the TB. The ones where you can replace it with something like SS, Z28 etc written on it.
Old Dec 6, 2002 | 05:31 PM
There is an open "chamber" under the TB top cover plate. That chamber connects 1) the port on the side of the TB that supplies clean/metered air to the PCV system, via the hose from the TB to the passenger side valve cover, and 2) the opening in front of the throttle blades that supplies that clean metered air.
If you remove the cover plate, you will open up the chamber, and allow unfiltered, unmetered air to enter the TB, and to enter the crankcase system..... in effect, it throws things pretty much out of whack, because the system (via the MAF sensor) no longer has any idea how much air is entering the combustion chambers. 93 speed-density systems would not have the air measurement problem, but you would still be admitting unfiltered air to the engine.
Old Dec 6, 2002 | 05:43 PM
krazzycowgirl's Avatar
I would leave it on. they dont weight that much Maybe 1.5 lbs if you are lucky.
heres a place were you can get nice ones to dress up your car. http://www.mbaproducts.com/
Old Dec 6, 2002 | 07:09 PM
PaulN64's Avatar
ok, questioned answered thanks
Old Dec 6, 2002 | 08:01 PM
superal's Avatar
It'd look very sh!tty without that cover on there. It's plastic so you'd maybe save an ounce of weight with it off.
camaroguy50613
May 27, 2016 09:00 AM
oldschool
Feb 9, 2016 09:21 PM
Newgmman
Feb 25, 2015 02:53 PM
Queens94z28
Dec 20, 2014 09:11 PM
heavenly_six
Dec 10, 2014 12:23 AM
