Taillight Conversion
Old Jan 23, 2003 | 03:26 PM
Dark Angel's Avatar
Ok. I got a page up with the directions and some pictures. Check it out. If you have any questions, just ask.
Taillight Conversion Mod
Old Jan 24, 2003 | 09:24 AM
94BlackBowtie's Avatar
Nice Guide! I may link to that or something on my 4th Gen. Lighting Guide website if you don't mind?
Old Jan 24, 2003 | 10:08 AM
KevinAce's Avatar
Hmm, I have a 99 3.8L Camaro and swapped the newer tail lights out for the older ones (the difference it makes is oustanding, I love them...looks a lot cleaner, and gets rid of the amber). I just swapped everything directly with no problems. I had to use a hack saw and cut out part of the tail light frame so that the tabs on the light sockets would slide in, then lock into place. Other than that...all went well. After reading your post, you made me worry, so I just went out and checked everything. All works well with all possible combinations (brake lights, headlights on, turn signals, etc etc).
Old Jan 24, 2003 | 12:10 PM
Dark Angel's Avatar
Does your turn signal work off 1 bulb and the brake off another? Also does the turn singal bulb also work as a tail light, so that the whole house lights up? That's what I did with this is made it so that for the taillights all bulb light, then convert to the single bulb Brake/Turn signal so that they weren't seperate.
Old Jan 25, 2003 | 04:01 PM
KevinAce's Avatar
I'm not sure exactly which bulb is which, my memory sucks and I'm too lazy to go check. Regardless, they're indepenant of each other - they don't work together at all.
Old Jan 25, 2003 | 05:02 PM
Dark Angel's Avatar
This is what the mod does. Makes them work together like the early style does. Then you have 2 or 3 (if you add another base) bulbs for the Brake/turn signal.
Old Jan 26, 2003 | 07:02 PM
KevinAce's Avatar
Oh, okay. I didn't know the earlier styles flashed together. Makes sense now...mine flash the same as before, just with the older housing.
Old Jan 26, 2003 | 08:42 PM
ZPaul2Fresh8's Avatar
I would like the Newer tail lights to touch up my 98+ front end, so is anyone willing to trade me their newer ones for my older ones?
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
cardemo16
Aug 24, 2015 01:04 AM
