t top question
Old Nov 15, 2006 | 03:32 PM
RKPsk8er's Avatar
t top question
is there a way to convert my 94 z t-tops to a targa top car? targa tops look sooo much better imo
Old Nov 15, 2006 | 07:54 PM
shock6906's Avatar
You won't have a roof section to use. It's a lot easier for hardtop cars to convert to targa.
Old Nov 15, 2006 | 09:48 PM
RKPsk8er's Avatar
what if I connected the ttops together so the targa top would be the ttops and tbar
Old Nov 15, 2006 | 10:56 PM
FuryZ28's Avatar
I'm sure it's possible, but it'll require A LOT of custom fabbing...
Old Nov 15, 2006 | 11:12 PM
shock6906's Avatar
You should go to your local junkyard with a reciprocating saw and hack the top off of a hardtop if you're wanting to go through that much trouble. It would be kinda cool to have a see through targa top though and you'd still be able to latch it on the outsides at least. You're still going to have to figure something out for the middle because I'm sure it wouldn't be as rigid as it was before. Personally, I think you're better off sticking with your T-tops for now.
Old Nov 17, 2006 | 07:50 AM
Craddock's Avatar
It's been done before, but it's honestly too much work.
Old Nov 17, 2006 | 01:47 PM
MistaCamawo's Avatar
I think it would be a mess for little gain
Old Nov 17, 2006 | 02:51 PM
Grims's Avatar
I saw a pic of a car that did it...it looked amazing. But, you have to do a ton of structural integrity mods.
Old Nov 19, 2006 | 10:22 AM
FuryZ28's Avatar
It all boils down to two simple things:
(1) How skilled you are at custom fabricating.
and just as important,
(2) How bad you really want to do this.
There are a lot of ideas that I thought would be cool for my car, but there's very few that I actually do, unless either I know I can do it, or if the skill level required is above mine, I find someone else who is skilled enough to do it. If you can do it yourself, the more important factor would be how much time you're willing to put into it without giving up on it, or if you pay someone to fab it for you, how much you'd be willing to pay for someone else to modify the car or part(s) for you...
I, for example, know NOTHING about metalsmithing, and so I paid a local metal fabricator to make me an extended, stainless-steel air deflector for $130, and my custom gauge cluster panel for $150 (that's only for his labor & materials, I still paid $1400 myself ordering the gauges and sensors)
Old Nov 19, 2006 | 01:57 PM
Grims's Avatar
can we get soem pics of that? Sounds awesome.
Old Nov 19, 2006 | 04:08 PM
Vikrel's Avatar
it would look awesome
Old Nov 19, 2006 | 04:38 PM
FuryZ28's Avatar
The fabricator just finished it yesterday, and he's going to ship it out to me on Monday, so I'll have some "installed" pictures by the end of the week, but here's a shot of it that he sent me via camera phone:
The two big gauges will be the speedo & tach, the left smaller gauge will be the oil pressure, and the right smaller gauge will be the water temp. My voltmeter and fuel level gauges will be mounted in a a-pillar dual gauge pod. The three tiny holes on each side are going to be my warning indicator lights (SES, Low Oil, etc.). The small hole that sits just above each smaller gauge will be my turn signals. The small hole @ the bottom in the center of the cluster will be my high beam indicator, and the upper hole that sits between the tach & speedo will be where I mount my Autometer mini shift light, which I'll be mounting it nearly flush with the gauge panel, so as to make it look like it came off the assembly line that way...
Also, in case you wanted to see it too, here is the extended stainless-steel air deflector that he fabricated for me:
Old Nov 19, 2006 | 10:01 PM
TechCam97's Avatar
Look up a member named Whistler, he's already done it.
capebuf
Jan 13, 2015 07:22 PM
ChrisFrez
Dec 7, 2014 06:01 PM
siguy
Nov 27, 2014 10:07 AM
The Seer
Nov 20, 2014 06:32 AM
Brent94Z
Mar 21, 2002 04:44 PM
