Steering Wheel Mod
Old Jan 14, 2007 | 09:17 PM
SROACH's Avatar
Steering Wheel Mod
One thing that I always disliked about 4th gen F-bodies is the steering wheel. Has anyone swapped their stock one with a nice custom one. I seen pics of a few 4th gens with this mod. I wondering how hard of a mod this would be?
Old Jan 14, 2007 | 10:51 PM
Bud M's Avatar
My Momo wheel was my first mod. Not too hard to do, you need a steering wheel puller and in my case I had to clearance the inside of the steering column cover for the Momo adapter. Also you will probably want to turn off the airbag light.
Old Jan 15, 2007 | 06:22 AM
SROACH's Avatar
Wow, that looks a lot better than the stock one. Thanks Bud M!!
Old Jan 15, 2007 | 10:06 AM
guywithaZ's Avatar
I s clearance an issue with all wheels and adaptors, or just the momos.
Old Jan 15, 2007 | 10:15 AM
detroit1994z28's Avatar
Re:
There's a member on the ls1tech site who posted this picture of there new steering wheel. After I saw this picture - I'm defently getting one for my z28 now. The best wheel I saw yet. It's the commander r wheel by momo
Old Jan 15, 2007 | 11:10 AM
The Grant wheels can be installed in the 4th Gens using the Grant 88/89 Camaro kit. The lower edge of the cover in the kit for the end of the steering column will rub slightly on the column, and needs to be sanded for clearance. The cover is also slightly smaller in diameter than the steering column, so you need to make sure the end of the steering column housing is painted.
http://www.injuneer.com/images/photo...r/DCP04309.jpg
Old Jan 15, 2007 | 11:11 AM
Bud M's Avatar
I would guess just the Momo. Mine was a little bit big in diameter so it would bind up against the steering column cover. I took a little bit of material off the inside of the cover with an air grinder and that fixed it. Easy to do. You could use a Dremel if you don't have air.
Old Jan 15, 2007 | 11:15 AM
guywithaZ's Avatar
Damn might just have to get me a new wheel...
Old Jan 15, 2007 | 11:40 PM
MarcR94v6's Avatar
The worst on the stock wheel is the location of the horns
Old Jan 16, 2007 | 10:57 AM
Eric@Victory Racing's Avatar
Old Jan 16, 2007 | 08:26 PM
danhr's Avatar
Which one is that eric@victoryracing?
Old Jan 17, 2007 | 09:30 AM
udlose94z28's Avatar
I changed it over with the grant kit 3196 on my 94 Z28. Adapter kit for the 3rd gen cars. U will have to space out the black adapter piece itself from the peice that slips over the splines on the column with washers to make room for it hittin the steering column. Not to hard, but VERY AGGREVATING for me. i took out the airbag wire out the column and all. that would be up to you
Old Jan 17, 2007 | 10:32 AM
Grant 673
Old Jan 18, 2007 | 04:12 PM
SROACH's Avatar
I want to do this mod maybe this summer.
Old Jan 18, 2007 | 04:36 PM
blackztpi's Avatar
i had a friend who put a bonneville wheel on a T/A it was a bitch and had to swap columns and shafts, but it looked good
