Static tint rolls
Old May 26, 2006 | 11:46 AM
mook99TA's Avatar
Static tint rolls
I need to tint my window but don't want to pay 200 for a professional tint. Any opinions for those of you who have done it? How did you put it on did you use adheasive or just soapy water and how long does it last? Also how did you do the massive back window?
Old May 26, 2006 | 01:17 PM
Z28SORR's Avatar
Re: Static tint rolls
One side has water activated adhesive, use soapy water. Make a template or cut to fit dry. Then wet down the window and tint, keep it wet so you can move it around. Don't take it all the way to the edge of the window, leave 1/8" to 1/4" from the edge or cut back with a razor. It helps if you keep the lower edge under the weather strip so it wont catch when you roll the window down, (remove the inner door panels). Once in place roll or squeegee out the excess water from under the tint. Use a heat gun for the curved area's. I consider the back window to be very difficult. Usually takes several smaller pieces.
I personally found this to be a real pain, and will gladly pay someone to do it.
Old May 26, 2006 | 09:10 PM
RENE95Z's Avatar
Static tint is alot thicker than regular tint. I doubt it would work for applications such as windows that roll down. The back window would probably be fine with the static tint. Although, to be honest, your best bet is to fork out the $200 to get it professionally done. I got mine done for $150and it was lifetime tint. I'm sure with a little shopping around, you can find someone to do it for less than $200.
Old May 26, 2006 | 09:16 PM
94Z28WP's Avatar
You'll never get the back window to look good unless you know what you're doing... I got my rear window tinted in one piece for $70... Pay someone to do the rear.
Old May 28, 2006 | 09:17 AM
69z-28's Avatar
pay someone to do it. im gonna be paying 300 for removing my current mirror tint and putting on some black limo all around. IMO its the best money you can spend on a car and have someone else do it. its such a PITA and usually never comes out how youd like. good luck if you do try it tho.
Old May 28, 2006 | 07:18 PM
Eddie Z-28's Avatar
Definately have it professionally done. A good window tint shop should be able to do it in one piece if they know what they are doing. A good friend of mine does tinting and he says there is a trick to them, but if you can't do it you aren't a professional.
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Bxlt1
Sep 10, 2015 08:16 AM
WPHIG2
Aug 27, 2015 06:37 AM
alphaauto
Jul 26, 2015 04:40 PM
