Removing tint
Old May 26, 2006 | 11:35 AM
Jim S. '95 Z28's Avatar
Removing tint
I need the remove the tint off of my side windows. I'll be leaving the tint on the rear glass because I don't want to risk messing up the defroster.
From what I've read, the process involves just peeling it off and removing the glue with a razor and window cleaner or soapy water. Would it help to park the car in the sun for a few hours to heat up the adhesive? Any other tips would be greatly appreciated.
Old May 26, 2006 | 01:21 PM
Z28SORR's Avatar
Re: Removing tint
Don't think it's that kind of adhesive. Just water, razor, and elbow grease.
Old May 26, 2006 | 03:44 PM
DustinZ28's Avatar
Re: Removing tint
glass cleaner, paper towels and a **** load of sharp razor blades.
Old May 26, 2006 | 03:57 PM
97BBlackZ's Avatar
Re: Removing tint
What i was told to do while i was taking mine off was to take trash bags and take some soapy water in a spray bottom.
Then spray the window and stick the trash bad to the window. Maby sure you get as much as the trash bag touching the glass as possbile and get the wrinkles out.
AFter thats done you set it out in the sun for a few hours then remove everything and peel it off.
It worked pretty good for me but i didnt get al lthe wrinkles out so it caught and tore in the places the glue was still pretty hard in.
Old May 26, 2006 | 07:57 PM
2000SilverLS1's Avatar
Re: Removing tint
Heat gun and a razor blade.
Old May 28, 2006 | 07:13 PM
Eddie Z-28's Avatar
Re: Removing tint
How old is the tint? Some of the newer tints will come right off. If not a mild degreaser and a razor blade. Sometimes the best answer for a tinted back window is just to replace it. Too much hassle imo.
Old May 28, 2006 | 07:25 PM
DustinZ28's Avatar
Re: Removing tint
yea when i took it off the back glass on mine it was a PITA!!! cant get all the glue off and the top where all the little circles are, it shows up white through the tint.
marlar98
Sep 19, 2015 07:53 AM
RX Speed Works
Sep 11, 2015 03:31 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
WPHIG2
Aug 27, 2015 06:37 AM
alphaauto
Jul 26, 2015 04:40 PM
