Squeak in trunk area....
Old Aug 2, 2007 | 10:59 AM
jare23's Avatar
I know this has been discussed multiple times in the past, but what has everyone done to fix this?
Old Aug 2, 2007 | 11:04 AM
Sparkz28ss's Avatar
rear seat latch....?
Old Aug 2, 2007 | 11:16 AM
EKO's Avatar
EKO
Mine was the spare tire wingnut being too loose.
Old Aug 2, 2007 | 11:26 AM
jare23's Avatar
i had the problem with my other camaro for the nut on the spare tire but im pretty sure its not the same squeak/rattle on this one. Any other guesses?
Old Aug 2, 2007 | 11:31 AM
The Captain's Avatar
I would check the spare tire, the jack, and the hatch itself. Why is this in the appearance forum
Old Aug 2, 2007 | 11:36 AM
shock6906's Avatar
+1 for spare tire stuff being loose.
Old Aug 2, 2007 | 11:38 AM
jare23's Avatar
I'll double check on those mentioned tonight once i get off work...and i was unsure on what section to actually put this one in. Let me know and i'll do it next time
Old Aug 2, 2007 | 06:44 PM
94_PatriotRed_Z's Avatar
yup that was my problem too.
Old Aug 2, 2007 | 10:13 PM
jare23's Avatar
Thanks for all the help guys
Old Aug 3, 2007 | 06:17 AM
94_LT1_Z28's Avatar
My antenna comes loose about every 10,000 miles, producing a very annoying squeaky noise over bumps... check that after you take out the spare tire
Old Aug 3, 2007 | 07:47 AM
JoeliusZ28's Avatar
the latch can squeak. I have electrical tape wrapped around the upper part of mine for that reason.
Old Aug 3, 2007 | 09:26 AM
Brangeta's Avatar
Spare tire, jack, hatchback latch, and the interior plastics on the underside of the hatchback can all squeak. Check them all.
Old Aug 4, 2007 | 11:18 AM
GKs96Z28's Avatar
+1 I had to do the EXACT same thing.
Old Aug 4, 2007 | 01:29 PM
30thZ286speed's Avatar
I glued some foam to the underside of the plastic spare tire cover, those pieces are so flimsy that it is hard to get them to latch down properly. Not only does the foam insulate sounds coming from the rear, it also adds some weight to those pieces and gives them some backbone. I also did the other side.
Another thing I noticed is the security shade/flap if I leave it open I hear rattles/squeaks but if its closed I don't hear them.
Aaront810
Aug 29, 2020 09:34 PM
Bxlt1
Jul 18, 2015 02:48 PM
240ssLs3
Jul 13, 2015 05:06 PM
squarehead
Nov 21, 2014 08:02 PM
