so i messed up my engine bay paint job
Old May 26, 2010 | 08:57 PM
z28beast's Avatar
how do i fix this? here the scenario i painted my engine with 2 coats of self etching primer and then 2 coats off black rust oleum. and 2 coats of clear it looked great! well when i was moving stuff around i scratched the clear! so i sprayed another coat of clear over the whole right side and it cracked! so now im freaking out and i have no idea how to fix this!
Old May 26, 2010 | 09:25 PM
94CamaroZ28/SSClone's Avatar
Sand it down.
Old May 26, 2010 | 09:28 PM
z28beast's Avatar
Originally Posted by 94CamaroZ28/SSClone
Sand it down.
well the last coat of clear is the only one that cracked...should i just sand that off then prime it again or just sand it down and coat it black again then re coat it with clear?
Old May 26, 2010 | 09:35 PM
I dont know? But I would sand off the clear that cracked and peal.
Old May 26, 2010 | 09:53 PM
Chevycrew's Avatar
Did you use the same brand of clear as the first time? Often different brands will give a bad reaction, involving pealing and cracking.
Old May 26, 2010 | 09:58 PM
z28beast's Avatar
yup i used the duplicolor both times... man this is sooo annoying!
Old May 26, 2010 | 10:01 PM
Black 97 SS's Avatar
when you paint you are supposed to re coat within a few hours or you have to wait a few days sometimes longer. The paint is curing and all the solvent havent released yet, this will cause the cracking.
Old May 26, 2010 | 10:10 PM
z28beast's Avatar
ok so what should i do now?
Old May 26, 2010 | 10:16 PM
Chevycrew's Avatar
I would wait a week or so, then sand the surface smooth, and re-clear.
Old May 26, 2010 | 10:18 PM
z28beast's Avatar
i posted pics in the lounge..lmk what u think...also do u think that will **** up the black? and what grit should i use?
Old May 26, 2010 | 10:20 PM
Chevycrew's Avatar
It wont mess up the black, unless you sand too deep. I would use a rough enough grit to remove the material, but not so rough that the clear wont fill the scratches. Sorry I cant give an exact number. Ill go look at the pics too.
Old May 26, 2010 | 10:24 PM
Chevycrew's Avatar
That might have disturbed the layers deep. Best thing is let it fully cure before messing with it, then sand till smooth and paint over it.
I just had this happen with some rust-oleum, I put the industrial paint over the regular primer. I had to go to bare metal to clean up the mess.
Old May 26, 2010 | 10:26 PM
z28beast's Avatar
damn it man! i guess ill post some better pics tomorrow after work.
Old Jun 2, 2010 | 10:11 PM
Evolution223's Avatar
you might as well forget about fixing it, you really cant sand it. just forget about it and let it be, it's not worth trying to fix on an engine, the more paint you put on it the hotter the engine is going to run anyway.
Old Jun 8, 2010 | 11:22 PM
z28beast's Avatar
????? engine bay broham. and the engine paint thing isnt true.....more paint on an engine will not noticeably affect performance
formula218
Dec 2, 2014 04:27 PM
Zaddiction
Aug 2, 2002 10:12 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
V6_Batmobile
Jul 22, 2002 06:26 PM
