So I changed my gauge bulbs....
Old Apr 23, 2003 | 10:15 PM
z28_melissa's Avatar
I changed my clear 194 bulbs in my dash to blue ones that I bought at wal-mart. Honestly, I'm pretty disappointed. I was going for an indiglo look but it turned out more of a dull turquoise than blue. I have a bright blue Pioneer cd player that I was trying to match but the colors really clash now.
Here's what it looks like.... but the picture makes it look more blue:
http://www.cass.net/~maak/bluegauges.jpg
Does anyone know of a different type of bulb, maybe brighter and a true blue (or even purplish) that doesn't cost a fortune? I got 10 of these cheap bulbs at walmart for under $16. Gimme some suggestions.... I may just end up buying the reverse indiglo gauges off Ebay.
Old Apr 23, 2003 | 10:25 PM
works now
Old Apr 23, 2003 | 10:51 PM
KillerTA's Avatar
Thumbs up
Very nice! Was it hard?
Old Apr 23, 2003 | 10:52 PM
How would I got about putting LEDs in? I thought I could only use 194 bulbs.
Old Apr 23, 2003 | 10:53 PM
ShelbyZ28's Avatar
Originally posted by ArcticYT95TA
Yep, works nicely. Guages don't look bad. You should check out www.superbrightleds.com I have heard a lot of people are buying from them, and they are fairly cheap. Other than that, I can only suggest doing real Indiglo reverse guages.
Ditto...get the quad 194 LEDs from www.superbrightleds.com . I have blue ones and they look awesome . They are a very bright blue, they definitely look sweet. I think they are around $2.30 a piece or something like that. You can get the look of blue guages for around $15 and they look like the Indiglo reverse gauges. I actually had someone comment on how much they liked my Indiglo guages and I was like I just put blue LEDs in.
Bryan
Edit: The LEDs will replace the 194 bulbs. They are the same thing just the LEDs are much brighter.
Old Apr 23, 2003 | 10:55 PM
not too bad... the hardest part was getting to the cluster, I had to take so much crap off, even my heater controls and the trim that goes along the top of my door (maybe there's an easier way.... but not that I could see). Once I got the thing out, the bulbs weren't too hard to replace other than the fact that the old ones were soldered to the socket things... I ended up having to just break most of the bulbs to get them out.
Old Apr 23, 2003 | 10:57 PM
Originally posted by ShelbyZ28
Ditto...get the quad 194 LEDs from www.superbrightleds.com . I have blue ones and they look awesome . They are a very bright blue, they definitely look sweet. I think they are around $2.30 a piece or something like that. You can can blue guages for around $15 that look like the Indiglo reverse gauges. I actually had someone comment on how much they liked my Indiglo guages and I was like I just put blue LEDs in.
Bryan
sounds perfect... I'll definitely check into those, thanks!
Old Apr 23, 2003 | 11:20 PM
mobleman's Avatar
shelby,
Which 194 leds did you end up using? There the single point or the 4 point designs.
I put the 4-point ones in my car and am not happy with them at all The light comes mostly out of the front of the bulb and does not illuminate the gauges evenly. If you used the single point leds I was wondering how much brighter than stock they turned out to be and if they distributed the light evenly on the gauges.
Do you have any pics of your gauges?
Old Apr 24, 2003 | 12:09 AM
6Speed's Avatar
Single point LED 194:
These 12 Volt Super Bright LED bulbs will replace T3-1/4 (#194/168) filament bulbs found in many automobile and water craft applications. They have an inverted cone shaped clear lens that causes the light to emit from the sides as well as the end.
4 point LED 194
These bulbs are the same size as the single led wedge base bulbs (replace 194 and 168 bulbs) but have 4 smaller leds instead of one large led. They are brighter but project all of their light out the end so are better for applications such as interior map reading lights.
The above came from superbrightleds.com
Maewens site contradicts this. Here is what his says
Shown at left are 4 Point LED's, These are highly recommended over single point LED's. They have a brighter illumination, and a wider angle of light projection).
So which is better?
Old Apr 24, 2003 | 06:06 AM
mobleman's Avatar
That's the reason I got the 4-point bulbs, I thought they would disperse the light better... Just need to find out if the 1-point bulbs do a better job than stock...
Old Apr 24, 2003 | 09:41 AM
It seems like the single point bulbs would do a better job. I'll buy some and let you guys know. Also... there's like 20 bulbs in the back of the cluster and it was hard to tell which ones I needed to replace. The ones that are already tinted I won't replace (blinkers, high beams, odometer, check engine light, etc). Is there a diagram anywhere that says what bulbs go to what?
If not.... I'll make one next time I take it apart, I'm sure it would come in useful for the next person that does this.
Old Apr 24, 2003 | 09:48 AM
ShelbyZ28's Avatar
I got the 4 point LEDs. I'm pretty happy with them for the most part. The lighting is not totally even throughout the guages but its close. But the color and brightness is great so I'm satisfied with them. Sorry no pics right now but I'll get some soon and post them here.
Bryan
Old Apr 24, 2003 | 09:52 AM
mobleman's Avatar
I think I have a double whammy here, since I also have the MAcewen white gauge overlays, new the bulbs are shining throug to layers of plastic instead of just one, excaserbating the light distribution problem.
Old Apr 24, 2003 | 10:07 AM
Maybe I'm getting ahead of myself here but has anyone tried using different colored LEDs, to make kind of a blending effect? Kinda like this:
http://www.cass.net/~maak/prettybulbs.jpg
I'm gonna try it.
Old Apr 24, 2003 | 10:48 PM
WonQuickZ28's Avatar
looks good
hey i think that looks pretty cool. its more blue than i thought it would be. i want to change mine to red, i think im going to now that looks really good.
nice DIY job!!
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
jj71787
Jan 31, 2015 10:20 PM
Collector Car
Jan 5, 2015 10:58 AM
