Shocks for Eibach Sportline
Old May 10, 2003 | 11:49 PM
  #16
Y2kPewterSS's Avatar
Thanks for the input guys, looks like I have a couple options. The camber is out because it ran out of adjustment on the control arm. It is actually -.3 deg now, spec range is -.1 to a +1 I believe. To me this is not a big deal. Some negative camber should cause the car to stick the front end a little better and get rid of some of the oversteer. The only negative of this is the tire will wear a little more on the inside.
You guys ever heard of this place? http://performance.auto-parts-wholesale.com/ They have Bilstein HD for $111 front $95 rear. The KYB AGX are $110 front $100 rear.
Brian
Old May 11, 2003 | 02:17 AM
  #17
94CamaroZ28's Avatar
www.stranoparts.com has the Bilsteins cheaper.
LS1 F-body parts list! Small sampling of our parts!
LS1 Camaro/Firebird parts
SHOCK ABSORBERS
Bilstein HD
Front: $95.30 each
Rear: $80.50 each
Package (all 4): $329.00
Old May 13, 2003 | 10:46 AM
  #18
Ok I decided to go with the Bilstein HD because they were the least expensive option for $330 a set. I found out that GM employees get a discount from Bilstein so I called them today. He told me the normal valving on the HD would not be adequate for the lowered car. He said they really need to be revalved or they won't have enough rebound damping to control the bounce after bottoming out against the jounce bumper. Revalved Bilsteins online are $480 BTW. To make a long story short, for any of you GM employees, you can get Bilsteins cheap. Bilstein HD $36 each revalved for an additional $25. Amazing deal and they were prompt calling me back and quite friendly.
Brian
Old May 13, 2003 | 12:48 PM
  #19
Predatorbird's Avatar
so GM employees can get revalved bilsteins for $244/set of 4? are they revalved for eibach's spring rates or any lowering spring? would any GM employees be willing to order a set for me if i sent you money?
karpetcm
Dec 16, 2015 09:07 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
KYWes
Aug 10, 2015 07:03 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
