Shaved Door Handle Install
Old Jul 22, 2009 | 09:56 PM
cteufert's Avatar
I just finished up installing the solenoids and control electronics to allow me to remove the door handles on my 95 Z28. It had the factory keyless entry but since I didn't have any remotes for it and even if I did it would not have been possible to lock / unlock the doors and open them separately. I ended up installed a aftermarket keyless entry system with 5 channels. Lock / unlock / driver door open / passenger door open / truck all are controlled by one keyfob.
I needed to install 5 relays plus the keyless controller to get everything to work the way I wanted. It was a rat's nest of wiring by the time I was done but everything tucked neatly behind the passenger kick panel where the factory module was previously.
Here are some photos showing the various parts of the install. I may post more details including a wiring diagram when I have more time.
Old Jul 25, 2009 | 09:33 PM
slomarao's Avatar
pics??
Old Jul 26, 2009 | 01:18 PM
n2ceptor's Avatar
People in the past tried, but since the doors are a plastic composite, its hard to find a filler that will not crack... Good Luck..
If I had an old donor door, I would probably give it a try, using different compounds to find one that might work..
Old Jul 26, 2009 | 01:29 PM
Chevyssoccer's Avatar
i used a donor door. It hasnt cracked but depending on the temp you can sometimes see it. I hope those actuators hold up for you because I would have used a lot heavier of a motor
Old Jul 27, 2009 | 09:13 PM
DAKMOR's Avatar
ugh,? buy a corvette?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Richardan15
May 30, 2015 08:36 AM
slothgrant
Aug 22, 2002 03:01 PM
