sanding the intake manifold
Old Oct 23, 2003 | 08:04 PM
Blackfire's Avatar
has anyone tried sanding down the intake manifold with fine grit sandpaper to get it to shine up? I have heard this works. What grit sandpaper would you suggest?
Brian Powers
Old Oct 24, 2003 | 08:51 AM
I haven't played with the intake manifold, but this procedure worked for a set of aluminum Baer brake calipers:
Polishing Baer Calipers
Baer caliper
Old Oct 24, 2003 | 11:45 AM
TransAm219's Avatar
I used a high grit sandpaper on my intake and then used never dull ( stuff you can buy @ wal-mart )
and it came out like this
http://www.cardomain.com/id/transam219
Old Oct 24, 2003 | 01:34 PM
MarkyMark's Avatar
Go
What sized grit sandpaper did you use? Intake looks really good and so does your car.
________
Live sex webshows
Old Oct 24, 2003 | 03:41 PM
TransAm219's Avatar
I honestly cant remember , I want to say 100/120 but I dont know .
I would just choose a good fine grit sand paper
It doesnt take as much sanding as you would think .
I did " wet sand " it but I am not sure if it makes a difference
Old Oct 24, 2003 | 04:30 PM
kingman109's Avatar
i took piece of 1500 grit emery (sp?) cloth and just quickly sanded the intake manifod and rails... and it started shining... basically use a rougher sandpaper to knock down any roughness then just jump up in grit till it comes out smooth and shiny and polish... no real trick or special process
Old Oct 24, 2003 | 05:45 PM
Blackfire's Avatar
thanks for all the help, your manifold came out awesome...i picked up some 320grit sandpaper and started out and its already looking good
Old Oct 25, 2003 | 06:36 PM
leadfoot94's Avatar
I thought I remembered seeing a guy do it with a bench grinder with a sisal (cotton) wheel, with lots of poilishing compound, and it came out almost like chrome It definitely looked cool.
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
