???'s about FF75s
Old Feb 11, 2003 | 10:12 AM
30thANNIVZ-28's Avatar
???'s about FF75s
Well My passenger Headlight and Foglight are out so I want to upgrade all to the FF75s. There has been alot of talk about them in here lately. I just have a few questions:
How hard is the install?
Cheapest Place to get them from?
Also if I do the headlights should I also do the FF75 Fogs or should I do some other fog light?
Old Feb 11, 2003 | 10:55 AM
94BlackBowtie's Avatar
The install is pretty simple - basically consists of just removing all the stock mounting stuff, and drilling a hole to put the mounting bolt for the lights through, and splicing into the stock harness.
Cheapest place - Advance Auto Parts. $59.98
Suggest doing all four headlights with the FF75's, and then whatever foglights you like. The FF75 won't fit in the stock foglight opening without extensive modification (to the best of my knowledge). There are quite a few fog's that will though...there is an install guide in my sig for an aftermarket pair that will.
HTH.
Old Feb 11, 2003 | 11:11 AM
Red1's Avatar
I just installed a pair this past weekend.
It's not hard to do. Biggest pain is aiming them. I pulled my car up to the front of my garage and turned my lows then highs on and marked in pencil where the middle of the beam was. After installing I was able to use those marks to line up the new lights. I need to replace my fogs now, they are aftermarket but don't look right now I might try Hella FF50's
cheapest place I found was like 94BlackBowtie said Advance Auto Parts.
Makaveli
Jul 15, 2006 02:58 PM
jasonwinn
Mar 16, 2006 12:02 PM
Z95m6
May 17, 2005 03:47 PM
Z95m6
Apr 10, 2005 11:54 PM
Cmr0z28
Nov 28, 2004 02:01 AM
