Rubber window guides keep popping up?
Old Feb 16, 2008 | 11:54 AM
ssbowtie1's Avatar
I have a 96 TA and the rubber window guides that attach to the top of the door have come loose. There seems to be some clip mechanism that holds them on, but every time I push them down, they pop back up.
Do I need to replace these pieces? Has anyone else had this problem and how did you solve it?
Old Feb 16, 2008 | 02:06 PM
Brangeta's Avatar
I'm not sure, but I would assume you just need to replace the clips.
Old Feb 24, 2008 | 12:28 PM
formula12345's Avatar
i have the same thing with my 1994 formula, its the passenger window, i would like to know how to fix it as well
Old Feb 24, 2008 | 02:43 PM
drJsl2008's Avatar
same thing for me, its chipping my door
Old Feb 24, 2008 | 04:15 PM
stylinbeaver's Avatar
I have the exact sam problem. My passenger side looks HORRIBLE. I have to push it back down ever so often to it doesn't come out.
Old Feb 24, 2008 | 04:21 PM
Counted Out's Avatar
http://shbox.com/1/adj_window.html
Hope that helps.
Old Feb 24, 2008 | 08:51 PM
WhiteZ95's Avatar
I had the same problem on the driver side.. looks bad, keeps chipping away at the fiberglass, and annoying when trying to roll the window up and down.. I just replaced the entire strip on both sides. no mo problems
Old Feb 24, 2008 | 10:23 PM
how did you replace the strips? i know theres some clip at the end of it but what did you do exactly??
Old Feb 24, 2008 | 11:28 PM
ssbowtie1's Avatar
Part numbers?
Details?
Old Feb 25, 2008 | 10:04 AM
Z28SORR's Avatar
A guaranteed fix, would be to do what they(GM) used to. And that's poprivet them to the door.
Old Feb 25, 2008 | 08:30 PM
rexcellent's Avatar
I had the same problem on my pass. side so i just bought a new one. What a PITA! It is such a pain to try to get all the little clips on and not scratch the hell out of you door. They also cost like $40 or $50 if I remember correctly, what a rip off. It definitely fixed it though but now my drivers door is doing the same thing.
Old Feb 25, 2008 | 11:54 PM
WhiteZ95's Avatar
Part numbers?
Details?
Im not exactly sure on the part numbers.. I will have to look into that for you. but for the installation I had both door panels and mirrors off at the time witch gave the window a little more room to move back while i slid the metal clips into their slots. Its actually not too bad if you just take your time.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
Camarokid95
Jun 12, 2015 11:25 PM
Jun 5, 2015 10:16 AM
mattstrike
Mar 11, 2015 07:33 PM
redleader
Jan 22, 2015 12:05 PM
