Rubber window guides keep popping up?
I have a 96 TA and the rubber window guides that attach to the top of the door have come loose. There seems to be some clip mechanism that holds them on, but every time I push them down, they pop back up.
Do I need to replace these pieces? Has anyone else had this problem and how did you solve it? |
I'm not sure, but I would assume you just need to replace the clips.
Originally Posted by ssbowtie1
(Post 5187431)
same thing for me, its chipping my door
I have the exact sam problem. My passenger side looks HORRIBLE. I have to push it back down ever so often to it doesn't come out.
I had the same problem on the driver side.. looks bad, keeps chipping away at the fiberglass, and annoying when trying to roll the window up and down.. I just replaced the entire strip on both sides. no mo problems:D
Originally Posted by WhiteZ95
(Post 5205185)
(Post 5205185)
Details? |
A guaranteed fix, would be to do what they(GM) used to. And that's poprivet them to the door.
I had the same problem on my pass. side so i just bought a new one. What a PITA! It is such a pain to try to get all the little clips on and not scratch the hell out of you door. They also cost like $40 or $50 if I remember correctly, what a rip off. It definitely fixed it though but now my drivers door is doing the same thing.
(Post 5205462)
Part numbers?
Details? Im not exactly sure on the part numbers.. I will have to look into that for you. but for the installation I had both door panels and mirrors off at the time witch gave the window a little more room to move back while i slid the metal clips into their slots. Its actually not too bad if you just take your time. |
