replacing automatic shift knob
Old Nov 4, 2002 | 08:39 PM
CasinovaThePimp's Avatar
Question replacing automatic shift ****
I have a '93 A4 Camaro, and I want to replace the shift **** on it with one out of a '95 (or similar) Pontiac Bonneville. How could I find out if they're compatible?
Old Nov 4, 2002 | 08:59 PM
96z's Avatar
96z
Does it look like a firebird one? If so they are compatible. I dont know of any exact way to tell. Im assuming all GM shift ***** should have the same "fit".
Old Nov 4, 2002 | 09:22 PM
The one I want isn't like the Firebird one, but I have seen pictures of Bonnevilles from the same year with shift ***** identical to the ones that are in Firebirds.
Did this make any sense?
Old Nov 6, 2002 | 06:11 AM
Severous01's Avatar
check the diameter of the shifter. then pull out the huge staple in the **** and replace with a new one. I replaced mine with one from a grand prix. swapped right over
Old Nov 6, 2002 | 10:02 PM
So I just take off the top part? No rewiring or anything of that kind is necessary?
Old Nov 7, 2002 | 03:19 AM
Severous01's Avatar
the only part you need to mess with is the leather part, not the metal part. Unless you wanted a shorter shifter.
Old Nov 7, 2002 | 12:03 PM
MysticTeal 95 V6's Avatar
Do you have the shifter around that you're wanting to swap out? It'd be easy to see if it'll fit or not. Simply remove the metal clip on the front of the stock shifter. Use something sharp to get under it if needed and simply pull out. Then pull the stock **** off and see if the new one will fit over the shaft. Make sure its seated all the way down and try depressing the button to make sure it'll change gears. I'm not sure how the Bonneville's **** is attached to the shifter though? If it too is held on with a clip then check to make sure that the clip that came out of the stock **** will fit... if not you may need to fabricate a way to make it stay
Hopefully I didn't confuse ya too much
QuickSilver02
Apr 7, 2015 11:12 AM
dale3in98
Feb 14, 2015 12:18 PM
Jason Short
Jan 19, 2015 06:34 PM
Jul 4, 2005 05:00 PM
redz_02
Jul 24, 2002 09:42 AM
