replace 97 driver side door bezel
Old Oct 29, 2012 | 09:54 PM
kozmosis's Avatar
I found the two plastic pieces I need, but I do not want to break anything trying to replace the small keypad piece and the large piece that goes around the door handle. It looks like there are three screws that hold the larger piece in place. I do not need to replace the window switches or door lock switch. So can I replace the plastic without taking the switches out.
Just purchased the 97 SS t-tops and 6 speed with leather.
Old Oct 30, 2012 | 01:25 AM
lymlyt96's Avatar
Re: replace 97 driver side door bezel
The switch panel pops in and out of the bezel just pop it out and you'll see the connectors underneath pull the switch panel from the connectors there's no clips so just pull and set aside then replace the bezel. When you put the new bezel in pull the connectors up and attach to the switch panel and pop it back in then you're done.
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
Hurin
Dec 13, 2014 07:38 PM
cmdeshon
Dec 12, 2014 10:51 PM
siguy
Nov 27, 2014 10:07 AM
Roshambo
Sep 4, 2002 11:25 AM
