Removing side molding and Trans Am badges
Old Jan 22, 2005 | 01:59 PM
RBE17's Avatar
Question Removing side molding and Trans Am badges
I want to remove the side molding and Trans Am badges from my '95TA. My intent is to remove the pieces w/out damaging the badges, molding or the car. I do not want to have to repaint the car. Any suggestions of a solvent or tools would be appreciated.
Thanks,
Steve.
Old Jan 22, 2005 | 03:40 PM
BLACKBIRD8200's Avatar
Re: Removing side molding and Trans Am badges
heat gun or some tough fishing line and goo gone
Old Jan 22, 2005 | 05:45 PM
RBE17's Avatar
Will the goo gone hurt the paint at all?
Thanks,
Steve.
Old Jan 22, 2005 | 07:32 PM
Brent94Z's Avatar
Super Moderator
Thanks,
Steve.
I've used it on my paint before... just don't use it in direct sunlight and make sure the surface is cool to the touch.
Also, do not SCRUB the glue off... gently rub it on the adhesive/glue and let the chemicals remove the glue. If you scrub it then, yes, you can damage the paint.
Lower's Avatar
If I had to do it over again, I would not do it.
Mine did not come off perfectly, even with fishing line, a heat gun, and about 10 hours of labor trying to get the last bits off.
It's not hugely noticable, but if you're a perfectionist, you should know there is a risk to it.
Old Jan 23, 2005 | 12:12 AM
Don't Look Back's Avatar
I agree. Once I get the lines in the body from the 10 years of having the trim there repainted, as well as the rust spot I found behind a piece of trim it will look good.
Old Jan 23, 2005 | 10:07 AM
Bawls's Avatar
I started removing mine last night. Just used my fingers and a can of "Bumper Sticker Remover" you can pick it up at any autozone. It sucks, Goof Off would have probably worked a lot better. But it got the job done... 3 hours later.
Old Jan 23, 2005 | 02:39 PM
1995greenTA's Avatar
I pulled my side molding, front bird, and "name tags" off, the only one I had any trouble with was the drivers side Trans Am. the rest came of flawlessly and left no marks. I just used my fingers for the job and the left over tape I rubbed off with my fingers (I don't imagine that will hurt the paint)
Old Jan 23, 2005 | 03:36 PM
ponyackn's Avatar
I just removed mine last night as well. I gave up on the passenger side goo. I'll have to do that another time. Waaay too much on the thumb
Old Jan 23, 2005 | 07:24 PM
OH yeah your thumbs will hurt
Old Jan 24, 2005 | 08:20 AM
RBE17's Avatar
Thanks for all the replies. I'm definitely going to be doing this. I've hated the side moldings since I bought the car, but have always been afraid to remove them. Not anymore.
Thanks,
Steve.
Old Jan 24, 2005 | 10:10 AM
Bawls's Avatar
It's nice when you wash your car now too, nothing in your way.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Patricklt1
Apr 24, 2015 06:29 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
