Removing Factory Steering Wheel...
Old Jul 20, 2003 | 12:36 PM
RCJim's Avatar
Angry Removing Factory Steering Wheel...
After buying two different steering wheel pullers and sweating a bucket full, I finally got my Factory Steering Wheel off... Well, Most of it -
It seemas as though the Rivets that hold a portion of the wheel together gave out and left a part of it on the shaft. (See Pics)
Any ideas on how to get this remaining piece off?
Old Jul 20, 2003 | 09:20 PM
MadKilla's Avatar
Hey RC, sorry about your problems with the wheel, its always something. If Run to discount auto and pick up a 2 or 3 claw puller or gear puller. That should be able to pop it right off. Some of them are labeled ball joint puller (what I use them for). Good luck man.
Old Jul 21, 2003 | 10:11 AM
RCJim's Avatar
Thanks for the reply, after a good nights sleep, I am ready to try again. I have some good ideas, I just hope one of them works -
Worse case, I replace the column cause I wont let it beat me!
Old Jul 21, 2003 | 10:53 AM
MadKilla's Avatar
Make sure your patient getting it off, and don't damage that steering shaft. If you busted it or gnarl up the teeth your headaches will multiply, trust me I learn everything the hard way. That $6.00 gear puller should pop it right off.
Victor Lamb
Aug 26, 2017 02:52 PM
Apr 16, 2015 09:57 AM
SLIMJIM
Jan 7, 2003 11:06 AM
TireSmoke
Aug 6, 2002 10:25 PM
