Removing the dot matrix on the hatch glass
Old Mar 16, 2009 | 11:34 AM
RRR's Avatar
RRR
Red face Removing the dot matrix on the hatch glass
anyone tried it and had any success? that stuff seems baked on and sanding wouldnt work i dont think. any kind of chemical that may be able to remove it?
Old Mar 16, 2009 | 12:28 PM
The Captain's Avatar
The most common thing I have seen done is put a piece of black vinyl over top of it. I do not think you can completly remove the dots.
Old Mar 16, 2009 | 12:36 PM
RRR's Avatar
RRR
yeah i've seen that but i want them gone if at all possible.
Old Mar 16, 2009 | 12:47 PM
Well, the only thing I can tell you is grab a box of razor blades and go to town. I wonder if there is some sort of solution you can put on there to make them come off.
Old Mar 16, 2009 | 04:14 PM
n2ceptor's Avatar
Might try nail polish remover in a small spot to see if it works..
Old Mar 16, 2009 | 05:45 PM
Counted Out's Avatar
If it is, or it is like, window tint then ammonia will help get it off.
Old Mar 17, 2009 | 12:19 PM
Mikey97Z's Avatar
The tint shop said you can't get them off. They really with they could.
Old Mar 17, 2009 | 06:24 PM
Future_Z_Owner's Avatar
i think those are etched onto the glass
Old Mar 17, 2009 | 07:22 PM
z28_theantirice's Avatar
Good tint shops will sand them down....
Old Mar 18, 2009 | 12:30 AM
ZRAPTOR's Avatar
You can't completelly remove them.You can make them less pronounced under the tint.Get a scraper and some extra blades and scrape them down.
When you do this if you have rear widow defogger scrape to the top of the hatch in case you slip.That way you won't screw up the defogger.Make sure you keep the blade as flat as possible to the glass so you won't scratch it.
Make sure you keep a sharp balde in the scraper.If you do this the tint will lay over the dots alot more evenly and won't be as noticable.I did this to the rear hatch of mine,the first one before the glass was busted out when the car was broken into and it work really well.Could hardly see the dots under the tint and i had 5% limo on the hatch glass.
Hope this helps out man.
Old Mar 26, 2009 | 11:59 PM
dilligaf241's Avatar
I just painted mine flat black. worked great and can't really see them at all now
Aug 5, 2015 08:35 AM
4586
Jul 31, 2015 06:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Jul 17, 2015 02:47 PM
