Removing door panels?
Old Apr 2, 2003 | 02:00 PM
SloMofo's Avatar
Question Removing door panels?
Is it a huge PITA to do on a 4th gen?
I will be swapping mine. Just wanna see what I am in for.
Old Apr 2, 2003 | 03:48 PM
CalPoly96Z's Avatar
There are two screws in the top side of the armrest which need to be removed and then two screws on the bottom side of the armrest. One of the screws on the bottom is a large one and the other is a smaller screw. Then there is one screw located behind the handle for opening the door and then you just have to pull the assembly for the handle and door lock off. For removing the door lock just pull hard directly away from the door and it will pop off. Remove the window switchs and door lock switch assembly and leave it hanging. Then roll the window all the way down and push in and pull up. You might have to wiggle it a little to get it to come loose. Altogether it isn't that bad of a project. Took me about 10-15 minutes to get the door off...
birdblack
Apr 20, 2015 04:24 PM
siguy
Nov 27, 2014 10:07 AM
yosshimura
Aug 14, 2002 07:29 PM
MilkyClr69
Jul 29, 2002 10:01 AM
Zomie
Jul 25, 2002 07:52 AM
