Remove tail lights?
Pop the hatch, and pull back the trunk liner. You will see a bunch of black plastic wingnut type things. Twist them off (There is one that is far on the outside of the tailight...its hard to reach but doable)
After you twist them off, just pull the lights off. When the light is out, find which bulb is dead and unscrew that part from the tailight housing.
