Racing seats...how hard to install???
Old Nov 23, 2003 | 08:54 PM
scyzoryk's Avatar
I am thinking abot buying some cheap ($200) racing seats from ebay. I was wondering how hard are those seats to install?? Anybody have a racing seats in their cars?? How are they???
Old Nov 23, 2003 | 10:23 PM
HUGGER_ORANGE's Avatar
i put a pair of tenzo seats in my Z and it took some work. i HAD to use the camaro seat rails because of the uneveness of the camaro floor and weld tabs on them. i then drilled holes through the tabs for grade 8 bolts. the holes in the new seats are wider than the holes in the camaro rails on my rasing seats. PLEASE DO NOT DO THIS UNLESS YOU ARE A CAPABLE WELDER. If you were to get into a wreak with halfas$ welds, it could kill you.
my Z28 is a semi-daily driver and with the high side-bolsters it can be a pain geting in and out all the time.
hope this helps.
Old Nov 24, 2003 | 10:42 AM
I installed a Corbeau Forza, and Corbeau has a "slider" type mounting bracket available, specific to the 4th Gen F-Bodys. Almost a direct bolt in. Only problem I saw was that I saved almost 20# over the stock seat/rails, then had to add a 10# mounting bracket and give back some of the weight savings.
If you race your car, be sure to read the NHRA or IHRA rules regarding aftermarket seats.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
canbaufo
May 5, 2015 03:43 PM
SpidermanForever
Aug 30, 2002 02:13 AM
