Racing Harnesses
Old May 12, 2003 | 06:59 PM
jas142's Avatar
Racing Harnesses
The seatbelts are lookin a little ratty and have seen better days. So is there anyway that I can get some Sparco 3 or 4 point harnesses in a 1993 TA with STOCK seats?
Thanks.
Old May 12, 2003 | 09:01 PM
fbird95's Avatar
You can get them, I dont think that they will be funtional with out a bar of some sort, most likely part of a cage to mount them too. I would just get some new seat belts at www.fparts.us or from ebay. Getting the harnesses with out proper places to mount them is going down the ricer route.
Old May 12, 2003 | 09:53 PM
Birdie2000's Avatar
G2 makes a bar that uses the top rear seatbelt mounts. It allows you to mount 5pt harnesses properly without a cage.
Old May 13, 2003 | 05:42 PM
jas142's Avatar
Thanks, where can I find their website or their products?
Old May 13, 2003 | 05:48 PM
StangInRearView's Avatar
here it is
if you decide to get it, send some pics, here it is
http://www.lgmotorsports.com/g2_prod...tm#harness-bar
Old May 13, 2003 | 06:07 PM
stik6shift00's Avatar
my friend (wasnt a camaro) just bolted them into the floor of the car....is something wrong with that
Old May 13, 2003 | 06:39 PM
SloMofo's Avatar
Not that I can see. Whatever works
Old May 13, 2003 | 07:16 PM
z28ponyeater's Avatar
yes there is, when you bolt the harness to the floor, if you were in a wreck the straps would put so much downward pressure causing the straps to slip around the seats breaking your back. they would probably break through your seats as well if they didnt slip around it. get the bar, a little over 200 and it will save your life.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
CARiD
Apr 8, 2015 08:08 AM
jbrockwell
Mar 14, 2015 08:44 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
