Put on my 18 Z06's....look at pic and tell me if it needs lowering!!!
Re: Put on my 18 Z06's....look at pic and tell me if it needs lowering!!!
Personally I'd remove the ground effects, and lower it. But that's me. If not, I'd just lower it about a 1". Maybe get some BMR springs and call it good.
Oh here's some before and after pictures of lowering my car with BMR springs.
Before
After
Before
After
shew that does look alot better...and that was only 1in. drop....was it with bmr's
what else did you do panhard bar?...shocks and all or just the springs b/c i've read horror stories about the rear setting to one side and all w/o panhard rod adj...lca relocation..and new shocks....and right now i can't afford if it takes all that to do it right?
I suppose you could lower it a bit.........although I think it looks good the way it is right now.
The fence, sitting on, am I.
In my opinion the car needs to be lowered.
I'd go with the Eibach pro kit springs with a 1.3 drop front & rear. The car looks great now but wait till it’s down a little more; it’ll look insane.
The Eibach's are great because they won't settle beyond their specs. With a 1.3 drop you won't have any problems going over speed bumps, bottoming out or rubbing the tires even with a full load of passengers.
I think it looks good the way it is... lowering it could make it look a little better but it's not worth it imo. I have WW gfx on mine and 17"/18" wheels... it looks fine not being lowered plus the extended air dam scrapes too much as is lol.
I had the same problem with my 95 vert when I put on the 18" ZO6's with P275 /35/18" tires all the way around. I got a nose bleeds from sitting up so high.
auright so i've got alot of mixed opinions but i took the poll down and you guys by lowering it was 12 to not lowering it was 7 opinions.
So from there I want to ask to guide me into what you guys think of as THE TOTAL lowering package where It Will Be Done Right.
what do i need......BMR's or SLP's, do i need a new panhard rod adj., what about new shocks?....what about lca relocation bars?...anything else to get it done right, please list all and I take it i can do all of these w/o any pro. install...b/c i'm pretty much aware of the f-body suspension
let me know on any of these mods that I need what's the best name brand on them also for ex: BMR, what kind of panhard bar, etc...
also do you think i'd be dissapointed with jut the Slp springs???
thanks for all the input
Defenatly needs to be lowered. Adjustable panhard bar and a good set of LCA's will help getting it off the line if you do decide to lower. The Pro-Kit might be a good suggestion for you.
but at this time in my life (just got married and all ya know
) i'm not really worried about dragging until about another year so do you think just springs would be sufficient enough right now b/c i'm not worried about wheel hop or anything......all i'm worried about is it rubbing, setting properly and riding okay as far as not hitting the bump jouncers i think their called...anyways do you think i even need to upgrade shocks???thanks guys
