Pulled off the ugly black plastic grill
Old Nov 18, 2002 | 04:37 PM
bradyb's Avatar
I pulled off my ugly grill and my front end looks so much better! Does anyone know what I should do with the remaining holes? Should I just have a body shop fill those in and reshoot it?
Thanks!
Old Nov 18, 2002 | 05:10 PM
LS1CAMARO's Avatar
I did the same thing and am going to put in a nice glossy black grill back in
Or if you like the look currently
Old Nov 18, 2002 | 05:29 PM
bradyb's Avatar
Here's a grill like mine that has been filled, this probably only looks good on a black car.
http://images.cardomain.com/installs...971_2_full.jpg
Old Nov 18, 2002 | 05:39 PM
LS1CAMARO's Avatar
NICE! How hard was the mesh to get in?
Old Nov 18, 2002 | 05:48 PM
bradyb's Avatar
I don't know but it dosen't look that hard, You can get to the back of those holes by removing the headlights. Some aluminum screen from home Depot could work?
Old Nov 18, 2002 | 06:06 PM
Zach94's Avatar
i like that look and am considering doing it...one question though...how would you attach the mesh?
Old Nov 19, 2002 | 05:45 AM
silv3rsw33t's Avatar
bradyb, are those camaro inserts or is that Camaro molded in the plastic, and if where did you get that at?
Thanks,
Travis
Old Nov 19, 2002 | 08:25 AM
bradyb's Avatar
The guy that did that only filled in the 6 holes where the grill attached, but other then that it is exactly how it looks under the black plastic grill. With the Camaro logo already being there I don't have any idea why GM would just slap on a plastic grill.
I just pulled mine off on Saturday, there are tabs on each side that are easy to pop out. You have three bottom tabs that you just pull out as well but you have to use some needlenose plyers and pinch the top three tabs that are secured into the front fascia.
With the aluminum mesh you could either screw it to the black Styrofoam that's behind the front fascia or you could even just silicon it to the back of the fascia. Mine doesn't have any mesh and it looks fine, up close you can tell there black Styrofoam behind the fascia but it's hard to see.
QuickSilver02
Apr 7, 2015 11:12 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Dec 17, 2014 11:00 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
