View Poll Results: Preferred center console for swap.
LT1 Chevy console.
18.92%
LT1 Pontiac console.
5.41%
LS1 Chevy console.
23
62.16%
LS1 Pontiac console.
13.51%
Voters: 37. You may not vote on this poll
Preferred center console.
Old Sep 20, 2006 | 01:50 PM
LT1 POWR's Avatar
Well my console lid completely broke off the other day and id like to upgrade from the stock console i have now. What is the preferred center console to swap into these vehicles.
Old Sep 20, 2006 | 02:32 PM
meissen's Avatar
Re: Preferred center console.
Is there even a difference between the Chevy and Pontiac consoles?
As far as I know, I have an 02 FBody console, I don't think there's much of a difference, atleast not for automatic. But, since you're replacing due to the console lid breaking off, LS1 without a doubt. LS1's hinge is metal, so you won't have to worry about the cheap plastic hinge in the LT1 breaking off. Plus, 4 cup holders, 2 accessory plugs... very nice.
Old Sep 20, 2006 | 02:50 PM
LT1 POWR's Avatar
Well i think the LT1 Chevy and Pontiac consoles are different. But yeah now that you mention it, I think the LS1 consoles are the same.
Old Sep 20, 2006 | 10:41 PM
6SpdLT1Z's Avatar
Correct.
Old Sep 20, 2006 | 10:46 PM
Resilient94LT1's Avatar
I like to have an LS1 console in my LT1... what kind of modifications does it require if any at all?
Old Sep 20, 2006 | 10:47 PM
shock6906's Avatar
I've got a 93 and a 97 Camaro and I'm fortunate enough to have the redesigned interior in the 97...it's really a lot better than the 93-96 style console and dash. The vents are a lot more effective and the added cupholder at the front is actually useful for something other than holding loose change. I also like the side opening console because it's not as cumbersome to swing out of your way to grab a CD, not to mention it's nowhere near as prone to breaking. I say the newer style dash is A+++++, as the ebayers would say.
So, all in all, the poll is incorrect since the newer console/dash design was in one year of the LT-1 cars.
Old Sep 22, 2006 | 12:15 PM
meissen's Avatar
Well, once you remove the LT1 console from your car, there's only a few differences.
My console didn't come with anything more than the console itself, shift plate, and lid... no mounting brackets or anything. Apparently there's mounting brackets so it mounts to the same spot where the LT1 tape holder mounts to (in the direct center of that cubby hole, you'll see the bolt I'm talking about). I've seen a few people just cut the two brackets off at the very front part of the console, I haven't done it myself yet but I probably will be doing that soon. The only true modification that you have to do is that the LS1 console has a peg in the center by the cup holder. On the LT1 vehicle, there is no hole for this peg. The peg helps with horizontal stability of the console. You can either cut the peg off and let the console wiggle a bit, or you can just get a drill bit for slightly larger than the peg and drill through the metal bracket that's there. I drilled the hole and the console is quite rigid... I guess the LT1 isn't as rigid? In all honesty, it's been so long since I've done this mod (It was the first interior mod I did!) that I can't even remember what my original 94 console felt like as far as how rigid and stable it was.
Hope that helps!
Old Sep 22, 2006 | 01:13 PM
Z95m6's Avatar
Go with the 97+ console, they're the same for both birds and Camaros. The 93-96 Pontiac console is junk as well the cup holder is non functional just like the early Camaro cup holder.
Old Sep 23, 2006 | 06:28 PM
BLK96Z28's Avatar
My console lid broke as well. Has anyone sucessfully fixed one?
Old Sep 24, 2006 | 09:14 PM
spydercam's Avatar
pics of 97- console?
Old Sep 24, 2006 | 09:43 PM
Z95m6's Avatar
I have a pic of mine before i installed it on the 4th page of my sig.
Old Sep 25, 2006 | 06:09 PM
spydercam's Avatar
man that is a whole lot better than my console-96! btw nice ride
Old Sep 25, 2006 | 06:16 PM
Z95m6's Avatar
Yeah the newer console is much better. It has 4 cup holders, 2 of which work great, the rear two kind of suck. The console hinge/lid is almost indestructable, it also comes with 2 cigarette lighters, and a small pocket in the front to hold a cell phone or other small items. Thanks for the compliment.
LT14LIFE
Nov 15, 2015 06:22 PM
WobblySausage
Oct 7, 2015 02:44 PM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
Sep 18, 2015 03:46 PM
maverickmk
Sep 1, 2015 09:17 PM
