Power Seats in a NON Power Seat Car???
Old May 23, 2005 | 10:50 PM
meangreen661's Avatar
Not Sure where this thread exactly goes but thought i would try it here. I sat in a t/a with power seats and it seems like i got a ton more room then in my car with manual seats. Is it possibly to put power seats in a non power seat car? BTW Did a search but didn't see anything.
Old May 24, 2005 | 11:11 AM
Z28SORR's Avatar
Re: Power Seats in a NON Power Seat Car???
Yes. This is not that hard, the seats bolt in and then you just have to power them.
Old May 24, 2005 | 12:39 PM
87DJP2001's Avatar
Tap into a hot wire at the fuse box. just run the wire under the carpet to the connection and use a inline fuse..
Old May 24, 2005 | 01:29 PM
krazzycowgirl's Avatar
depending on what type & year for the car check under the carpet you might find the power wires.
Old Apr 16, 2007 | 12:55 PM
adamz28's Avatar
Is it possible to buy power rails and convert my existing manual seats to power?
Old Apr 16, 2007 | 01:48 PM
jasonisdn's Avatar
i have a power seat that came in my 96 ss (gray leather) that work fine. i need to switch to a racing seat for the 5 point harness so i am willng to part with these i guess. make a offer if you want . i'll even trace the wire and cut out the harness and end that with it and take photos of everything to help you get it all wired up.
Old Apr 17, 2007 | 09:45 PM
AlfredB18's Avatar
Why would you need "power rails"?
I almost guarantee the wiring harness is pre-installed at the factory and you need only to add the seats and plug the harnesses together...
Old Apr 17, 2007 | 09:49 PM
adamz28's Avatar
I was trying to avoid having to buy a new power seat. I just wanted to upgrade my existing manual seat.
Old Apr 17, 2007 | 09:53 PM
if you want the controls which you most likely will you do need to get your hands on a power rail yes but you can get them from almost any junk yard or on ebay for fairly cheap.
Old Apr 17, 2007 | 09:54 PM
Moshbmx1's Avatar
The harness is in the car yes, try and get a used power seat, im sure you can find them cheap if you search around the forums
Old Apr 18, 2007 | 09:51 AM
Squeaky192's Avatar
I swapped a power seat in mine, and the power and ground were already run and everything, just plugged it in and went.
Joes96z
Dec 14, 2014 04:03 PM
owen66
Nov 30, 2014 04:21 PM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
