Polishing Guide
Old Jan 6, 2004 | 01:46 AM
c0rey's Avatar
Polishing Guide
Hey i was wondering if anyone has a polishing guide out there anywhere. I looked at the search and couldnt find anything that was too helpful so I figured i would make a post. I want to polish the stock valve covers, so i was wondering if anyone has a guide out there with step by step insturctions?
Old Jan 6, 2004 | 07:01 AM
94BlackBowtie's Avatar
http://groups.msn.com/Camaro2001SS/polishinghowto.msnw
That one comes from Todd 2001SS (you may want to look at some of his site pics).
http://www.eastwoodco.com/lib/buffin...inum_wheel.asp
That one comes from Eastwood, the company you would be best off using to get all your supplies. It is detailed for wheels, but can be helpful in other areas as well.
Old Jan 6, 2004 | 10:00 PM
Firstgenboy's Avatar
i have a print out of a post from a while ago.. in the post it says to use mothers polish.. then take non-amonia windex and clean it off and then apply z-2 with zfx and the polish will last for a while
Old Jan 6, 2004 | 10:05 PM
c0rey's Avatar
I'm talking about taking a painted item to a polished finish.
Old Jan 7, 2004 | 06:36 AM
Strip the paint off of the item with "Aircraft Stripper" (available at Wal-Mart) and then see the two guides I posted above.
Old Jan 7, 2004 | 11:29 AM
kgkern01's Avatar
How hard would you expect it to be to strip and poilish some silver stock 5 spoke TA wheels? Would it even be worth it to try?
Old Jan 7, 2004 | 01:28 PM
Stripping is simple - it's just a matter of spraying that stuff on there, letting it sit about 15 minutes, then rinsing/rubbing it off (USING GLOVES!!!) - then repeat until it's stripped. It's simple stuff really, not even laboriuos.
Polishing a previously unpolished wheel is a MAJOR pain in the butt. Not only does it take a very very long amount of time it takes a lot of work, and tons of elbow grease.
It just depends on how bad you want it and how much you enjoy it. Just sand it with all the different grades of sand paper from coarse to rough, then start the polishing. It ain't fun or easy, but it makes wheels pretty.
Old Jan 17, 2004 | 09:45 AM
Eliminator's Avatar
Not to jake a thread but what do you use if you still have factory rims what cleans them the best,? thanks
football4life
Oct 4, 2015 07:48 AM
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 14, 2015 09:20 AM
Aaront810
Sep 11, 2015 11:24 AM
Daluchman1974
Sep 11, 2015 06:12 AM
