Polished my fuel rails and intake manifold
Old 08-22-2009, 01:12 AM
Mikes 1994 z28's Avatar
Picked up a $10 polishing kit at Home Depot today and went to town on the fuel rails and the top of the manifold. In all I have about 2 hours into this. The fuel rails were really easy to do and didn't take much time at all. I started with the rough polish and work my way down to the very fine polish. 4 stages in all. The top of the manifold I started with 150 grit on the sanding block then progressed to 340, 400, 1200, 2000 then went threw the polishing stages. It probably would have helped to have 600 or 800 grit around but I didn't want to run out and buy some. The best part was I didn't have to removed the rails (just removed the bolts and MAP sensor) or manifold at all. It helped a bunch to have a dremal with felt rollers to get in between the injectors on the sides.
Before:
After:
Mikes 1994 z28 is offline
Old 08-22-2009, 09:42 AM
Maverick_997's Avatar
Niceeeee!!
Maverick_997 is offline
Old 08-22-2009, 09:50 AM
RS96Silver's Avatar
looks great! im gonna b doing mine soon
RS96Silver is offline
Old 08-22-2009, 05:33 PM
slowride94z's Avatar
that does look good
slowride94z is offline
Old 08-23-2009, 10:14 AM
Did some more polishing yesterday. Next im going to do the TB and MAS.
Old 08-24-2009, 05:13 PM
Lt1 and Ls1's Avatar
Much better!
Lt1 and Ls1 is offline
Old 08-24-2009, 11:58 PM
Larsv8's Avatar
How long did it take you?
Larsv8 is offline
Old 08-25-2009, 06:33 AM
Fuel rails - 30mins
Fins on the manifold - 1:15 hours
By the MAP - <2:00 hours, It was pretty rough. I had to take it down quite a bit to get the surface smooth.
HectorM52
07-30-2017 11:46 AM
LT14LIFE
02-09-2015 09:35 PM
birdblack
12-30-2014 06:59 PM
07-04-2005 05:00 PM
Quick Reply: Polished my fuel rails and intake manifold
