polished aluminum
Old May 2, 2007 | 11:01 AM
DiabloGT's Avatar
polished aluminum
im using a power tool with a wire wheel at the end with a fine sand at the end, and want to keep my parts as shiny or even nicer than it is. what can i do to keep it like that in the engine or how often do i have to use a certain polish or polisher and what do i use?
thank you
Old May 2, 2007 | 03:04 PM
thesoundandthefury's Avatar
When you say "polish," were you meaning your intentions are to get a mirror finish? By using a wire wheel, all you'll really accomplish is getting the part(s) clean. If just getting the parts clean are your intentions, there are much easier ways.
Old May 3, 2007 | 09:26 PM
DiabloGT's Avatar
well it looks slightly polished though haha, but how can i keep that look? and i have some other billet and polished or chrome ones, what can i do to keep them like that without corrosion and all nice?
thanks
Old May 5, 2007 | 09:20 AM
Go to Autozone and buy one of these:
...and use it with any off the shelf metal polish of choice.
Old May 6, 2007 | 05:55 PM
DiabloGT's Avatar
have you ever tryed that before? and what do you think of this:
http://cgi.ebay.com/ALUMINUM-POLISHI...QQcmdZViewItem
Old May 6, 2007 | 08:31 PM
Yes, I use mine pretty frequently. I like it because before, whenever I'd get done polishing a part and had globs of leftover buffing compound to get off of it, I'd have to go through the tedious task of using either brake cleaner or talcum power with a microfiber towel to saturate the compound so I could wipe it all off by hand. Now, with the Powerball, all I have to do is wipe on some Mother's and buff it off: the polish "liquidates" the compound and the Powerball soaks it up like a sponge.
I already asked you if you were looking to get a mirror finish, and you said this:
The Powerball will "keep that look" much more easily and with less mess than the kit you linked. I use the parts in that kit all the time to make an unpolished part look polished, but for the purposes of regular maintenance and upkeep, they're overkill.
Old May 7, 2007 | 02:20 AM
FireChicken1995's Avatar
if you really want the polished look you are going to need a buffing pad that is mounted to something HIGH speed not just a mother power ball on the end of a cordless drill. if you have a air compressor you could get a high speed grinder from harbor freight pretty cheap the find a buffing wheel to attatch. you will also need buffing compound i use some stuff thats in a bar form and after i get that to bling up the part i use blitz to get a lil more shine out of it plus blitz makes a coating on top that helps the shine last.
Old May 7, 2007 | 09:04 AM
"One Up" this:
...since apparently, I don't know what the **** I'm talking about.
Unless the original poster is purposefully trying to be deceptive, I believe all he's asking for is tips on how to keep his already polished parts looking nice, which the Mother's Powerball does perfectly.
Old May 7, 2007 | 01:16 PM
what the **** ever man im sure it took you a while with the power ball that is up there with the god crated LS1..... iv been around this for all my life and i know what im doing. im not saying you cant use a power ball so dont get your panties in a bounch. people like you **** me off b/c if its not your way you get all pissy about it. blow it up your ***.
moving on......
Old May 7, 2007 | 04:14 PM
Never said my way was the only way. I was merely trying to make a helpful suggestion. If I sounded "pissy," it's because I don't appreciate when somebody tries to step on my nuts by saying that my way is wrong.
Old May 7, 2007 | 08:54 PM
DiabloGT's Avatar
wow how long did it take you for the intake because i want to do that to mine! and would the best way be to buy that kit on ebay then use mothers to maintenance the look, or just keep using the mothers? and what other compounds and buffers besides mothers can you use to get that look? or http://www.eastwoodco.com/shopping/p...iProductID=950
thanks
p.s. sorry i dont have any clue about polishing
Old May 7, 2007 | 09:41 PM
thanks
This is an excellent "how-to" article from one of the site sponsors, Eastwood Co.:
http://www.eastwoodco.com/jump.jsp?i...8&iSubCat=1445
Here's a little writeup I did that shows the tools I use to polish and gives a brief description of the function of each:
http://www.z28.com/forum/showpost.ph...4&postcount=22
The tools in that Ebay link are an example of what you'd use if you were starting off with a rough cast or unpolished part, so they would be necessary for doing something like an LT1 intake. The Mother's Powerball and metal polish are used to maintain the shine on parts that have already been polished, after they get cloudy and oxidized from being exposed to the elements.
The intake manifold was 40 hours of labor.
Old May 7, 2007 | 11:01 PM
DiabloGT's Avatar
on the first article it says to fine sand the aluminum to 220 but yours is 600, which one is it, and if i get the whole intake sanded down to that grit then i can bascally just start buffing it correct? and wouldnt i just be able to buy that ebay kit instead of sanding it or it doesnt work that way?
thanks
Old May 8, 2007 | 12:14 AM
From the Eastwood article:
"Aluminum and other soft metal surfaces need to have a surface as smooth or smoother than what a 220 grit abrasive would yield."
This statement is kind've misleading. It has to be taken into context with how complex the shape of the part is and what type've buffing wheel/bits will be used. To start buffing at a grit this low, you'd have to use a sisal wheel which is way too aggressive of a wheel to use on something like an LT1 intake because it would mar and deform all the corners and edges. You'd sand to 600 grit so you could use a softer spiral sewn wheel or felt bob which allows you to maintain more precise control over the shape of the part.
General rule:
Less sanding = more buffing
More sanding = less buffing
The trick to this is to get the part as smooth as possible with sanding so that you can get away with the least amount of buffing.
Yes.
and wouldnt i just be able to buy that ebay kit instead of sanding it?
You need to do both.
Old May 8, 2007 | 08:26 AM
shock6906's Avatar
Wow, if either of my cars were dedicated show cars, I'd have all the metal parts off of them polishing them up right now. Those pieces look great!
