polished aluminum
im using a power tool with a wire wheel at the end with a fine sand at the end, and want to keep my parts as shiny or even nicer than it is. what can i do to keep it like that in the engine or how often do i have to use a certain polish or polisher and what do i use?
thank you |
When you say "polish," were you meaning your intentions are to get a mirror finish? By using a wire wheel, all you'll really accomplish is getting the part(s) clean. If just getting the parts clean are your intentions, there are much easier ways. :)
well it looks slightly polished though haha, but how can i keep that look? and i have some other billet and polished or chrome ones, what can i do to keep them like that without corrosion and all nice?
thanks |
Go to Autozone and buy one of these:
http://us.st11.yimg.com/us.st.yimg.c..._1944_35400892 ...and use it with any off the shelf metal polish of choice. |
have you ever tryed that before? and what do you think of this:
http://cgi.ebay.com/ALUMINUM-POLISHI...QQcmdZViewItem |
and what do you think of this: well it looks slightly polished though haha, but how can i keep that look? |
if you really want the polished look you are going to need a buffing pad that is mounted to something HIGH speed not just a mother power ball on the end of a cordless drill. if you have a air compressor you could get a high speed grinder from harbor freight pretty cheap the find a buffing wheel to attatch. you will also need buffing compound i use some stuff thats in a bar form and after i get that to bling up the part i use blitz to get a lil more shine out of it plus blitz makes a coating on top that helps the shine last.
Originally Posted by FireChicken1995
(Post 4586761)
http://i46.photobucket.com/albums/f1...lternator2.jpg http://i46.photobucket.com/albums/f1...y/IMGP0512.jpg http://i46.photobucket.com/albums/f1...t1intake11.jpg http://i46.photobucket.com/albums/f1...est400pic1.jpg http://i46.photobucket.com/albums/f1...eadsafter3.jpg http://i46.photobucket.com/albums/f1...1mafafter5.jpg ...since apparently, I don't know what the **** I'm talking about.
what the **** ever man im sure it took you a while with the power ball that is up there with the god crated LS1..... iv been around this for all my life and i know what im doing. im not saying you cant use a power ball so dont get your panties in a bounch. people like you piss me off b/c if its not your way you get all pissy about it. blow it up your ass.
moving on...... |
wow how long did it take you for the intake because i want to do that to mine! and would the best way be to buy that kit on ebay then use mothers to maintenance the look, or just keep using the mothers? and what other compounds and buffers besides mothers can you use to get that look? or http://www.eastwoodco.com/shopping/p...iProductID=950
thanks p.s. sorry i dont have any clue about polishing |
(Post 4588365)
thanks p.s. sorry i dont have any clue about polishing http://www.eastwoodco.com/jump.jsp?i...8&iSubCat=1445 Here's a little writeup I did that shows the tools I use to polish and gives a brief description of the function of each: http://www.z28.com/forum/showpost.ph...4&postcount=22 The tools in that Ebay link are an example of what you'd use if you were starting off with a rough cast or unpolished part, so they would be necessary for doing something like an LT1 intake. The Mother's Powerball and metal polish are used to maintain the shine on parts that have already been polished, after they get cloudy and oxidized from being exposed to the elements. The intake manifold was 40 hours of labor. |
on the first article it says to fine sand the aluminum to 220 but yours is 600, which one is it, and if i get the whole intake sanded down to that grit then i can bascally just start buffing it correct? and wouldnt i just be able to buy that ebay kit instead of sanding it or it doesnt work that way?
thanks |
(Post 4588676)
"Aluminum and other soft metal surfaces need to have a surface as smooth or smoother than what a 220 grit abrasive would yield." This statement is kind've misleading. It has to be taken into context with how complex the shape of the part is and what type've buffing wheel/bits will be used. To start buffing at a grit this low, you'd have to use a sisal wheel which is way too aggressive of a wheel to use on something like an LT1 intake because it would mar and deform all the corners and edges. You'd sand to 600 grit so you could use a softer spiral sewn wheel or felt bob which allows you to maintain more precise control over the shape of the part. General rule: Less sanding = more buffing More sanding = less buffing The trick to this is to get the part as smooth as possible with sanding so that you can get away with the least amount of buffing. and if i get the whole intake sanded down to that grit then i can bascally just start buffing it correct? and wouldnt i just be able to buy that ebay kit instead of sanding it? |
Wow, if either of my cars were dedicated show cars, I'd have all the metal parts off of them polishing them up right now. Those pieces look great!
