Pics of my interior
Old May 28, 2004 | 08:21 PM
  #16
MikeStank's Avatar
the camaros can be done like that, the firebirds have a red film over the backing which is not easy to remove
Old May 28, 2004 | 10:01 PM
  #17
coogsLS1's Avatar
I didnt know that, thanks for the info!!
Old May 28, 2004 | 11:44 PM
  #18
Brent94Z's Avatar
Super Moderator
That looks great! I like it. A lot of times I don't like many interior mods like that but as has been mentioned previously, I think yours came out "classy" looking!
Old May 29, 2004 | 05:50 PM
  #19
SpeC's Avatar
Did you change the lights in the doors that illuminate the locks and windows switches? What LED bulbs did you buy from that place?
-Derek
very nice by the way!
Old May 30, 2004 | 11:44 AM
  #20
MikeStank's Avatar
Yes, i pulled out the red bulb and its holder from behind the doors, and just widen the hole a little so the new LED would fit in. The bulbs i bought are the Part Number: RL5-B5515 Honestly, i think you can go with the weaker ones in the doors, I'm not going to change mine out now though
Old May 30, 2004 | 06:29 PM
  #21
cbuns55's Avatar
Did you just use regular old spray paint? If so, what brand of paint? I bought the Wal-Mart brand silver and clear, but i have yet to do it. Any other suggestions before I dive into painting?
Old May 30, 2004 | 10:04 PM
  #22
Buffdaddy's Avatar
I like the interior especially the blue lighting!
Old May 30, 2004 | 10:54 PM
  #23
PDCamaro318's Avatar
looks sharp....nice job
Old May 30, 2004 | 11:08 PM
  #24
MikeStank's Avatar
wow, i like all the good responses
Crazyjim, ithought about a differnt shade, but that is a CLOSE match to my exterior, but after seeing it with my aluminum overlays a darker shade would set them apart. When my car gets painted i'll decide then.
cbuns55, I used the plastikote stuff from pepboys. It worked well for me, except i had a can of clear that was spitting and i have a few dark tiny spots on my guage bezel. Some stress prepping more than anything, I do recomend sanding as it doesn't take much longer. Primer is not neccessary, but i again recomend it, it will at least show you how good your sanding job is before the base coat. only need to base coat it until it looks good, then spray clear till you dont' want to anymore. clear needs to be really light smooth coats if you want a nice smooth finish. Start with easy pieces like the radio bezel and the door trims, the bezel is the hardest to do because of the curves. Don't try to rush all the pieces in one day unless you have the room to lay everything out.
My finance already scratched one of my door pieces with her ring, so i'd strongly recommend fewer coats to keep it thin, although I think she would have scratched the unpainted surface with how hard she hit it Sometimes I think about not allowing passengers in my car.
Old May 31, 2004 | 02:05 AM
  #25
doombunnie's Avatar
I like it a lot
Old Jun 3, 2004 | 08:44 AM
  #26
stangkilla1's Avatar
I see nothing rice about it!!!!
good job man. The factory lighting is so dim that you almost HAVE to upgrade to something different. You should check out "rhinosarehorny" car. He did something like that to his including his vents.
Old Jun 3, 2004 | 10:50 AM
  #27
2Poor4Z's Avatar
as far as the gauge lighting go.. the camaro have a blue film in all of their gauges, HAVC, and headligth control **** areas. I have replced all of my lights with white LEDS and it still has a sort of bluish tint to it. You cannot remove this film period. You can however do a gauge cluster swap out of a camaro into a TA if you want the Blue gauges. I have seen it done several times. The LEDS behind the gauges are size 194 bulbs and are just straight plug in
Old Jun 3, 2004 | 12:20 PM
  #28
MikeStank's Avatar
I was under the impression that they weren't an exact replacement, am i wrong
Old Jun 3, 2004 | 12:21 PM
  #29
MikeStank's Avatar
I have 5 feet of electro light tape here, i'm not sure what i want to do with it if anything. it was my original idea for adding some light to the aluminum.
Old Jun 3, 2004 | 10:10 PM
  #30
)2overt SS's Avatar
I don't see any rice
Awesome job
