photoshop these rims for me!!! please racing hart m5's
Old May 6, 2003 | 11:13 PM
stik6shift00's Avatar
http://store3.yimg.com/I/topendimports_1733_11573627
there racing hart m5's....could anyone photoshop!
yeah, dont be like fast and the furious wanna be just cause there on the orange supra!
Old May 7, 2003 | 12:38 PM
Does anyone know what the bolt battern is for a 00 camaro? Will these rims even fit?
Old May 7, 2003 | 01:42 PM
jwade95Z's Avatar
You need a 5*120.65mm (4.75in) bolt pattern. There are some on the board who have used the BMW bolt pattern 5*120mm, but that would be your call. If you do a search, you see some pretty good commentary from engineer types regarding the risks of varying the bolt pattern, even less than 1 mm, based on the design of the lug nut and it's relation to the hub and wheel stud.
The offset you will need depends on the width of the wheel. For a 9 inch wheel, you need a high positive offset, +50mm. The stock SS wheels are 17*9 with a +50mm offset. With 8 inch, you could get away with a lower positive offset, closer to +40.
Simply put, the offset determines where the wheel will sit in relation to the body panel. For the same width, a higher positive offset will push the wheel in toward the car, and a lower positive offset will push the wheel more outward.
Old May 7, 2003 | 02:03 PM
pu12en12g's Avatar
This guy is running M5's on his Z...
http://camaroz28.cardomain.com/id/nickz95camaro
Old May 7, 2003 | 07:48 PM
I think that looks good!
In my opinion better on a black ls1
Old May 9, 2003 | 12:14 AM
White30th's Avatar
http://camaroz28.cardomain.com/membe...187_1_full.jpg Vin Diesel???
karpetcm
Aug 14, 2015 03:02 PM
Boss002
Jul 24, 2015 10:47 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
mrwz28
Jul 8, 2015 09:11 PM
