Passenger Side Wire Mod -->Done! Got Pics
Old Oct 27, 2004 | 06:24 PM
  #16
NoFear95's Avatar
Re: Passenger Side Wire Mod -->Done! Got Pics
Just make sure you use something to make sure your wires dont rub on the hole you cut to loom the wires through. I rapped them in plastic loom and then in rubber hose. Could find a rubber grommet that size.
Old Oct 27, 2004 | 08:49 PM
  #17
jakef2003's Avatar
I did this a while ago. Definately cleans the bay up. We also have the same STB.
Old Oct 27, 2004 | 09:02 PM
  #18
joshp007's Avatar
I actually used a jig saw since the connectors were rectangular. I moved the red box down by where the washer fluid neck is. Sorry i havent had time to send pics yet. Been workin too much! I will asap. Anyone that wants pics just give me your email
Old Oct 27, 2004 | 09:07 PM
  #19
NoFear95's Avatar
No problem. Get it when you can.
Old Oct 27, 2004 | 10:55 PM
  #20
Metlhed54's Avatar
i like ur car man looks clean as hell. good job.
Old Oct 28, 2004 | 08:09 AM
  #21
NoFear95's Avatar
Thanks again!
Old Oct 28, 2004 | 09:23 PM
  #22
ssbowtie1's Avatar
I thought you had to lengthen the wires?
Old Oct 28, 2004 | 09:27 PM
  #23
dmoor88's Avatar
using black looming is another option
Old Oct 29, 2004 | 09:26 AM
  #24
NoFear95's Avatar
I didnt have to lengthen any wires. There is plenty of slack to pull everything through. Only wire I had to lenthen was the Knock sensor mod wire I had on the ground. But if you dont have it dont worry about it.
FOr the hole I used the black looming covered in rubber hose. 2x coverage.
Old Oct 30, 2004 | 02:06 PM
  #25
bad93z's Avatar
That looks awesome, I just may have to try it
Old Oct 30, 2004 | 06:59 PM
  #26
Pandamonkey's Avatar
Very clean lookinng - shiny too!
Old Oct 30, 2004 | 07:56 PM
  #27
NoFear95's Avatar
THanks guys!
Old Nov 14, 2004 | 11:57 AM
  #28
LT1 Bunny's Avatar
how do u guys get rid of the little red box and the ground??
Old Nov 14, 2004 | 03:11 PM
  #29
n2oblkz
Guest
Posts: n/a
I just moved the ground to the inside of the innner fender from underneath using the same threaded hole. I left the red box for now, I was not sure of what to do with it.
Old Nov 16, 2004 | 03:44 PM
  #30
LT1 Bunny's Avatar
yeah thats what i figured...just curious to see if anyone made up a new ground or something!
has anyone gotten rid of the red box? other than taking it off ...actually re-locating those wires as well?
